Go to Post A Strong FRC Team Should... have a clear vision and an understanding of how to achieve it within their means. - jwfoss [more]
Unread 30-10-2012, 11:38
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: #25 Chain Drive Experience ???
During my time on 1503, we ran #35 chain in the drivetrain. While #25 is plenty strong enough, the biggest concern was sprocket allignment. Rather than spend hours machining spacers to 0.0005" tolerances, we felt our "quality" maching time could be better used for the parts that really needed it.
Personally, I'd rather spend the extra time and run #25 chain all around. The weight savings is huge.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 30-10-2012, 12:00
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We generally use #25 for mechanisms and #35 for the drive-train.
According to AM #35 chain is .25lb/ft and #25 is .10lb/ft. In a drive train that used 16ft of chain (average for us I think) #25 series would save 2.4lbs vs #35.
This weight difference could be reduced by using smaller sprockets and no tensioner with #35 chain. We've used half-links to tension our #35 chain drives during initial assembly, never touched them after that, and never thrown a chain in the 3 years I've been coaching.
Unread 30-10-2012, 12:35
Brandon Holley's Avatar
In my 12 years, I've run #25 chain on 9 robots (1 other was #35, 2 others were belts) and never threw a chain. You definitely don't need 0.0005" tolerances to get the alignment right. What you do need is careful design, and a little love at final assembly to ensure everything fits as designed.
I understand the "bullet-proof persona" that comes along with #35 chain, but I think any team is capable of using #25 if they want to. It just comes down to taking the time and effort in areas where you usually may move fast. Theres no need to machine spacers of +/- 0.001" of each other when you can buy shim stock and punch out spacers in whatever size you may need.
I know our final assembly of our drives with chains was carefully done over a couple days to ensure everything fit as intended. This is at the point where all of the pieces of the drive are DONE: machined, polished, cleaned, anodized. It's often tempting to rush and throw every piece together in an hour. I think our track record shows taking your time at this step is time well spent.
One reason we actually switched to belts was to make assembly a bit faster, which absolutely did decrease the time required at that step.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 30-10-2012, 12:45
Chris is me's Avatar
AKA: Pinecone
Honestly, in our experience (a short run in a gearbox and a short run for a big arm), alignment was important but not absolutely critical or anything. I mean, for teams without a lathe that use the Kitbot and extruded parts, 25 might be a challenge, but if you have any reasonable manufacturing capability it's more than doable.
Unread 30-10-2012, 14:15
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Generally chain "stretching" is every little join on every link wearing.
The reason you see more stretch on #25 is not because it is weaker but is because you have more links per inch to wear down.
Unread 30-10-2012, 18:10
Aren_Hill's Avatar
Build Nifty Things
It is also partially attributed to the lubrication slowly working its way out of each pin joint.
A guy who likes robots.
