#16
Re: Castings in FRC
In 2011, we overmolded performance wheels with a urethane tread. Performed well, but we've also had good luck with the Hi-Grip wheel that came out in 2012. Here's some pics of our setup..
https://plus.google.com/photos/10248...CK2p1N3ssbWSRQ |
#17
Re: Castings in FRC
A friend of mine has built one of these waste oil furnaces. It gets hot enough to cast iron, (which he has done). There are only a few hobbyists who ever attempt casting iron. This is an order of magnitude more difficult and dangerous than casting aluminum. For aluminum casting a propane furnace is clean, convenient, and not overly expensive unless you plan to do a lot of casting. Some folks use a charcoal furnace, which is easier to build from scratch, but does have additional drawbacks. The waste oil furnace is relatively expensive to build, quite large to store, and requires a fairly large, open, and dry yet fire-safe area to operate. A location suitable for casting with a propane furnace is generally easier to locate. You might try checking the cost of just a used stainless steel keg sometime to see how quickly the parts start to add up.
#18
Re: Castings in FRC
Our art department casts both aluminum and brass. Some of the other schools in our area have the same capabilities in their art departments. Artists are a good source of experienced people and equipment that can help with casting.
#19
Re: Castings in FRC
Re: Castings in FRC
Hi All
Last year we needed 2” x 7” dia. aluminum material for wheels We had lots of scrap from robots over the years and I have an electric kiln, I had not done any casting with aluminum for years, (like others I learned foundry at high school) with no green sand we used plaster for a mold (after it was baked to remove the moisture) it worked well enough to get us the billet material at a reasonable cost. It was a great experience in Up-Cycling and I have hopes that we can explore more options this year, To that goal I have invested in a set of foundry tools and built a molding bench. I should say “made” a set of tools and a bench as most of the tooling was outrageously priced for as simple as it is. I went with petro-bond sand instead of mixing my own “home brew” a little more expensive but better results too. Altogether total cost was about $400.00 including the kiln + time and brain power I have found many books on the subject on amazon If there is an interest I will list materials resources and supplies as I did with 15c machine shop. Have Fun Geo. |
#21
Re: Castings in FRC
Did you attempt any heat treatment afterward? (If so, what was the process, and how did it go?) |
#22
Re: Castings in FRC
If you plan to do some casting, it is best to get your raw metal from scrap castings. That way you know the specific alloy was appropriate for casting in the first place, and not stamping, extruding, machining, etc. There is a lot of scrap metal out there, so if you hook up with the right source it is usually easy to get enough of the correct raw material at modest or even zero cost for casting projects. The real issue with casting is having a safe location and the right tools and experience to do the work in a safe manner.
#23
Re: Castings in FRC
Ive seen teams use casting of metals - but have any of these teams tried using this process to create stronger metals.
For instance: say you were making a wheel shaft out of steel. You could add just a trace ammount of beryllium to the steel and close to double your strength. Without adding any weight. It's sort of a bad example but I'm curious if any teams with a material sciences mentor has experimented with alloying their own metals. Last edited by JohnSchneider : 31-10-2012 at 10:41. |
#24
Re: Castings in FRC
We did not send any of our cast samples out for analyses, so I can’t comment on the alloy content, other than you are correct as most of the material we used was 6061 with a good helping of 6063 If we decide to cast gears, high strength components or wear parts it would be a different story, in this case a bit of zinc would go well, fyi Blast from the past; http://www.youtube.com/watch?v=fJyD8...eature=related Have Fun Geo. |
