Go to Post Don't try to kiss your stapler remover, those prongs are sharp... - MissInformation [more]
Unread 31-10-2012, 10:28
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Castings in FRC
Ive seen teams use casting of metals - but have any of these teams tried using this process to create stronger metals.
For instance: say you were making a wheel shaft out of steel. You could add just a trace ammount of beryllium to the steel and close to double your strength. Without adding any weight.
It's sort of a bad example but I'm curious if any teams with a material sciences mentor has experimented with alloying their own metals.
