Go to Post We want to go out and build something right away. But it is better to think a little bit first. - ChrisH [more]
Unread 31-10-2012, 14:25
litterClean litterClean is offline
FRC #3734
litterClean is an unknown quantity at this point
Example java code?
Hey, our Team is having trouble creating working java code. We are able to communicate with the Crio, however we can't get any of the four cims, which are controlled by jaguars, to work. Does anyone happen to have some basic example java code for consoling a robot with four cims?
Unread 31-10-2012, 18:04
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Example java code?
Command-Based or Iterative style? CAN or PWM?
The FRC Java starter guide covers the drivetrain code for Iterative starting on page 11
http://firstforge.wpi.edu/sf/docman/...tation/doc1199
The WPILib programming cookbook covers the Command-Based drivetrain starting on page 14
http://www.wbrobotics.com/attachment...ibCookbook.pdf
There's going to be a few minor differences from both of those documents if you're using CAN or an arcade drive however.
Most of the other code I've come across in teams public repositories is more complex than that in the documents, but if you'd like to look at that as well:
https://github.com/Neal/VikingsBot-2...vikingrobotics
https://github.com/frc3946/ReboundRu...reboundrumble/
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
