Go to Post We are different, but in our differences we help the world continue to grow, change, become inspired. Different is NOT bad. Be true to your self, be weird, be dorky, be crazy, be a geek. :) - chellyzee93 [more]
Unread 29-09-2012, 19:36
digitalgoldfish digitalgoldfish is offline
FTC #5961
digitalgoldfish is an unknown quantity at this point
Grade Slope for Robot Ramp
Hello All,
Forgive me for any errors as this is my first post on Chief Delphi, but anyway;
We, the Vashon Pirate Team 5961, are considering building a ramp on our robot for our alliance members to drive up, and we were wondering what grade of slope can your robots drive pp?
Unread 29-09-2012, 19:42
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Re: Grade Slope for Robot Ramp
I moved this to the FTC forum.
This isn't a thing that people test for since there isn't an on-field ramp. If we were pursuing this sort of design, I'd recommend to my team that they build something that's no steeper than 15* or so because teams are usually really, really terrible at driving straight up an incline.
--Madison--
...down at the Ozdust!
Unread 29-09-2012, 20:14
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
I agree with this and also suggest that the ramp be coated with high friction material for good traction, but I am not sure what is actually legal. Double stick tape perhaps.
The second thing to consider is to have a lop at the sides so that it is less easy for wheels to drive off the sides.
-Dick Ledford
Unread 01-10-2012, 11:59
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
just FYI: last year, the slope of the ramp was 18 degrees: http://www.usfirst.org/sites/default...CTIONSEPT6.pdf. Given that we can increase traction by using materials other than plain plywood, I think that 20 deg would be OK.
Unread 01-10-2012, 13:27
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
In FRC we did a couple platforms that were basically a 1 foot rise with a 3 foot long ramp. This gets you right aroun 30-35 degrees. This was similar to the ramp in the 2006 FRC game. This was very difficult for a lot of teams to climb, but not impossible. Look back over the 2007 FRC game and see what some of the folks did there.
Unread 01-10-2012, 16:37
arcsin(1 / 3) = 19.4712206 deg
Unread 02-10-2012, 13:42
IKE's Avatar
AKA: Isaac Rife
no team (N/A)
Good catch.
Unread 22-10-2012, 16:57
MisterStig's Avatar
MisterStig MisterStig is offline
Enough Said
AKA: Austin
FTC #4076 (RoBUGs)
MisterStig is an unknown quantity at this point
I would agree that 20 degrees is safe and maybe also 25. I also suggest adding non-slip material, such as the stuff used on stairs.
If you have the time, you can test your ramp by building some simple robots. Try using different will sizes/types and also make the robot different weights.
Unread 22-10-2012, 18:25
MisterStig's Avatar
Enough Said
AKA: Austin
FTC #4076 (RoBUGs)
I agree that 20 degrees is safe and maybe even 25. Also, I suggest adding non-slip material such as the stuff used on stairs.
If you have the time, you can test your ramp by building a simple test robot. Try using different wheel types/sizes and try increasing/decreasing the weight of the robot.
Unread 23-10-2012, 15:16
MisterStig's Avatar
Enough Said
AKA: Austin
FTC #4076 (RoBUGs)
Having delt with several ramp before, I would say 20-25 degrees would be safe. Also, I suggest adding non-slip material such as the stuff used on stairs.
If you have the time, build a seperate (simple) robot so that you can test your ramp. When testing, try using differnt wheel types/sizes and be sure to change the weight of the robot also.
Unread 31-10-2012, 20:02
Telthien
Posts: n/a
Two years ago? Probably around 55 degrees.
Last year? 25.
This year, I really don't know, but I don't imagine it being more than 15 or 20.
It varies from robot to robot, and is not a stable measurement. Best idea is to go as low as possible so the largest number of robots can drive up.
