Go to Post We want people to exercise Gracious Professionalism® and play at their best, but also not really because we find this archaic rule to satisfy something related to inspiring students to pursue careers in science and technology.™ - PayneTrain [more]
View Poll Results: How wide are your treads? (don't vote if you don't have them)
<3 cm (1.18 in) 2 8.00%
3-3.9 cm (1.18-1.54 in) 0 0%
4-4.9 cm (1.57-1.93 in) 4 16.00%
5+ cm (1.97 in) 19 76.00%
Voters: 25. You may not vote on this poll
Unread 15-01-2003, 00:38
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
Treads... How wide?
For those teams that are using treads, what width are you using? (english or metric) Why?
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 15-01-2003, 00:51
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Wider is better
Hypothetically, if we were to use a track drive base... we would probably go with a 2" wide belt. That is, if we could turn with such a thing.
Wider belts get better traction, which also causes pain while turning.
Heck, we're almost two weeks into this and we don't even know which type of drive base we are using. sigh.
Andy B.
Unread 15-01-2003, 02:41
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
2"
two inch belts have worked well for us in the past. as Andy said, turning does become harder as the belt gets wider so its important to always add a bogey wheel near the center turning point of your base. this wheel should be slightly lower than the others to provide a smaller turning point for your bot. if done right you'll utilize the belts traction but lower side loads and friction while turning. good luck.
Anthony Lapp team 221 --> 857
Unread 15-01-2003, 18:16
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
It needs to be that wide atleast.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 16-01-2003, 22:27
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
width
we've had bad problems with treads, even though the traction is amazing, turning creates a whole new set of trouble. the amount of torque required to turn is immense and is related to surface area to ground, so don't have too much traction otherwise the motors will draw too much power and reset constantly. also you will get heat problems, so don't completely encase them, leave an airflow channel and add fans! before you chose your timing belt, experiment as to which one gives the best traction without being to hard to turn, and keep in mind that each tread could have as much as 65 LB pushing down, so weigh them down when testing. also too much tread can leave a metallic ice from Colombia two years ago, where they physically could not move because the motors did not have enough output.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 17-01-2003, 00:09
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
I actually want to see some 2-3 inch treads. That'll be real cool with a LOT of traction
Unread 17-01-2003, 00:44
AKA: Anthony Lapp
ask and yee shall recieve
an old pic of one of our treaded bots!
Unread 17-01-2003, 09:58
R2K2D2 R2K2D2 is offline
AKA: Raj
R2K2D2 has a spectacular aura aboutR2K2D2 has a spectacular aura about
Send a message via AIM to R2K2D2
go with whatever makes it easy to turn w. once again if in the middle of the track you have a lower point of contact, that will allow the robot to turn more easily. traction wise it is not going to make a difference because the coefficient of friction equation has no variable for area, so the amount of tread does not matter in that regard.
Unread 17-01-2003, 10:31
Ideally, yes... but not in reality
If we go by the F=mu equation, then yes... there is no consideration for area.
However, after a slew of friction pull tests on the steel grating and HDPE, there are differences. (hint - FIRST is going to Texas for the Championships... bigger is better)
This is the type of thing that Woodie spoke of during the kickoff... you can design and theorize all you want, but the sooner you get to testing your ideas and seeing how things actually work, the better off you will be.
Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat".
Andy B.
Unread 17-01-2003, 15:48
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Ya know this is kinda a pet peve of myne...
ok, get this.. the formula for friction "supposedly" doesent have any realtionship to surface area....
however it does to normal force... and normal force is in direct relation to surface area..
If what half of the ppl on the boards say was true.. you would see dragsters running on tires .5" wide... more normal force= more friction or so they say.
Personally.. I say WIDER IS BETTER! within reason of course.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 17-01-2003, 17:50
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Before this turns into another "Area matters" vs. "Area doesn't matter" in terms of friction thing, check out this thread.
Unread 17-01-2003, 18:13
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
tread size
The current plan for our robot this year is to have treads 4 inches wide. Last year we had three inch wide tread and never had any problem turning. We use a half-track design with omni-casters in the front to decrease the turning problem. The reason we want to use that much tread is to have as much traction as possible on the ramp and on the HDPE.
Connecting motor to treads Carl Owenby Technical Discussion 10 16-01-2003 22:21
Tank treads and specialty wheels archiver 2001 7 24-06-2002 01:25
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
Wheels, treads... Dan 550 Rumor Mill 23 19-12-2001 15:38
