Go to Post So I thought to myself "Man, I wish I was a part of a large technically minded community... oh... right..." - BordomBeThyName [more]
Unread 16-10-2012, 18:15
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
Re: AndyMark CIMple Box Stripped Out
Originally Posted by Adrian Clark View Post
I think many of us would like an explanation as to how exactly a stripped gear made your gearbox lock up.
Sorry it took me a while to get back to you. It is possible the metal shavings got wedged between the gears, or the CIM gears which were stripped didn't mesh with the output gear. Also, when I said it locked up, I meant it provided heavy resistance and wouldn't turn over without seizing.
Originally Posted by sanddrag View Post
Oiled or greased?
Greased with a high pressure lithium grease, as I have come to find out.
Unread 18-10-2012, 16:10
AKA: Bobby Van Ness
Oiled or greased?
Unread 25-10-2012, 20:10
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Photos would be great!
Unread 26-10-2012, 23:10
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
The little tubes of grease that come with the CIMple boxes work great. We have a stash of them since we usually build transmissions and don't open the cimple boxes, but if you have some, those are great. We actually had the same issue this year at SBPLI, but we greased it a lot and it spun like a pro.
Unread 29-10-2012, 08:44
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
We had the same problem. One must not have been lubed up as much as the others. We had it lock up and we came to find out that both sets of gears had about 90% of the teeth gone and their shavings mixed in with some grease at the bottom of the box.
We make easy things look difficult, everyday!
Unread 29-10-2012, 09:38
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We've found that you can't put too much grease in a CIMple box... literally! If there's too much in there, it'll work its way out in the first few minutes of running it - just turn everything up, wipe off what comes out, and you're good to go.
2016: Lake Superior WFFA
Unread 29-10-2012, 13:06
AKA: Bobby Van Ness
Actually I posted an image of it before, heres the link:
http://postimage.org/image/l4hxqnftx/
Thanks for your interest
We're just lucky it didnt happen in competition
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 31-10-2012, 10:31
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
  1. How much did your robot weigh?
  2. What was the sprocket reduction from the gearbox to the wheels?
  3. What type of material (box tubing/KOP/Sheet metal) is your frame made out of?
  4. How much did your robot weigh, with bumpers but without battery?
  5. What size diameter were the wheels?
2017 Scoring Model
CAD Library | GitHub
Unread 31-10-2012, 17:23
AKA: Bobby Van Ness
I dont have the specifics at hand, but I'll try my best.
Our robot was 119.9lbs w/o bumpers or battery.
I cant remember exactly what it was, but it would top out around 10fps.
1" aluminum box tubing 1/8th" thick.
With the bumpers, I believe it weighed around 130lbs.
We used the 6" kit wheels.
Unread 01-11-2012, 09:38
JesseK's Avatar
FRC #1885 (ILITE)
Nothing seems out of the ordinary here. Weight/Gearing aren't out of wack (good speed for a heavy bot). A frame with that tubing can be crazy stiff if welded properly.
How crazy were your drivers during your competitions? Where there many instances of slamming the robot controls the opposite direction when the bot was at full speed?
Also, is there any possibility that the output shaft bearing popped out slightly (the one in the plastic, where the encoder goes)? Any sort of lateral stress on the CIMple box output shaft (over-tension on chain, massive shifts in control that are opposite the robot's momentum which 'snap' the chain into high tension) can lead to fatigue in the plastic over time that causes the bearing to unseat. This could cause the opposite bearing on the output shaft (the one in the metal) to seize, which could then cause the CIM gears to shred. It only takes 1-2 degrees of bearing misalignment for these bearings to become VERY inefficient; any more and they probably did seize.
2017 Scoring Model
Unread 01-11-2012, 09:40
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
That does look like classic lack of lubrication. I know we have done it before ourselves.
Unread 01-11-2012, 13:12
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I measured the components of the CIMple gearbox including the 56T gear and output shaft. These parts are made to a loose fit tolerance. This in both the fit to the bearings and the fit to the 56T gear. Much looser than anything I have designed. It seems it would take quite a bit of misalignment for anything to bind.
Question - Is the 56T gear plated in your gearboxes?
Andy Brockway
Team 716, The Who'sCTEKS
Unread 01-11-2012, 13:35
Chris is me's Avatar
AKA: Pinecone
The image strongly implies not enough lube in the gearbox. You REALLY need to pack those things with grease and make sure they stay lubricated. Some teams use a clear spray-on lubricant that makes their gearbox look ungreased, but don't let that fool you - you need grease.
Unread 01-11-2012, 20:50
I second the cyclical fatigue motion. Constant running would likely not shred the gears, but high stress cyclic loading would cause them to fatigue and eventually the teeth would fracture. Perhaps your drivers were cycling the controls back and forth when the gearbox seized up to get the robot moving and this resulted in the gears becoming stripped.
Just a thought.
