Go to Post ask not what your alliance picks can do for you, but what you can do for your alliance picks. - Swan217 [more]
Unread 02-11-2012, 17:28
paper: Talon, Victor884, Victor888, and Jaguar speed vs torque tests
Thread created automatically to discuss a document in CD-Media.
Talon, Victor884, Victor888, and Jaguar speed vs torque tests by Ether
Unread 02-11-2012, 17:29
Re: paper: Talon, Victor884, Victor888, and Jaguar speed vs torque tests
That's great.
Could you use the same axis settings for all graphs, to make it easier to compare?
How were the PWM pulse widths chosen?
Unread 02-11-2012, 17:48
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Joe Ross View Post
That's great.
Ether did these tests in my lab. The PWM pulse widths were selected to provide a range, in 50 us increments, that fully exercised each controller; i.e., we increased the pulse width until further increases did not yield increased speed. This limit was different for each controller.
I see what you mean about the axis settings -- while they are all the same physical size, the torque axis tick labels and gridlines for the Victor 888 do not include odd multiples of 0.1 N-m, as the other do. However, if you blink between the graphs for different controllers there is no shift in scale or origin, so they are actually quite easy to compare.
Richard Wallace
since 2003
Unread 02-11-2012, 18:04
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Ether, if I examine the graph for the CIM with the Victor 884, it shows that at the top PWM setting, the Victor gives significantly less power than any other of the motor controlers. Di you simply not go to the top PWM setting for that motor controler? Is the 884 truely weaker?
Also, your results seem to show that the motor curves, even at full power, are slightly diferent across motor controlers. Is this an artifact of the testing? If it has to do with the electronic characteristics of the motor controlers, could you elaborate on the design implications?
-Plutarch
Unread 02-11-2012, 18:28
It was an oversight. I have the data but it did not make it into the graph. I will post an update later this evening.
...your results seem to show that the motor curves, even at full power, are slightly diferent across motor controlers. Is this an artifact of the testing? If it has to do with the electronic characteristics of the motor controlers, could you elaborate on the design implications?
The switching method, output PWM frequency, parts selection, and circuit design of a controller can affect the motor performance.
Unread 02-11-2012, 18:29
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
Nice work, very useful.
Could we get the raw data in a spreadsheet, CSV or txt file format so we can import for use in other analysis programs? Thanks.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 02-11-2012, 19:15
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Thank you for the update.
I was wondering more about the possability of diferent motor controlers being slightly more optimal for diferent applications. For example, the Talon appears to have slightly more power at high load compared to a Jaguar. Does this mean that it would be better for an application where spikes into high load are expected, such as an elevator? Or is this just another artifact of testing and graphing?
Also, to give more concrete numbers it would be nice if you could upload the Excel files you used for the graphs. I always find a table easier to use for motor curves.
-Plutarch
Unread 02-11-2012, 19:37
RevA has been posted. It includes 2.00 and 2.10 ms curves for the 884 graph. Also the tic marks on the 888 torque axis were changed to match the other graphs.
The graphs were created with gnuplot, and the raw data does not contain metadata identifying the plots. I'll work on that after I finish processing and posting the results of the inrush current tests.
Unread 03-11-2012, 18:41
dsirovica's Avatar
dsirovica dsirovica is offline
Programming and Electrical Mentor
AKA: Dean Sirovica
FRC #1458 (Red Ties)
dsirovica is on a distinguished road
Nice work Ether,
if its not too hard to do, it would be great to see a plot taken all the way to stall and show the Current drawn for Highest PWM, for the FRC approved speed controllers.
I suspect many/most robots are not designed to operate in the optimal range, but are driven to operate in the extreme regions, so it would be a great teaching tool to show the inefficiency when operating in the extreme, and therefore the importance of good design.
This would also show the Jag cutting out way before a Vic does. Though the 2013 Jags apparently will not have a current limit?
Dean
Unread 04-11-2012, 21:04
Updated revB posted. Four graphs were added to present the same data as a family of RPM vs PWM curves at constant torque.
Unread 05-11-2012, 21:45
OK guys. The raw data has been posted. Knock yourselves out. :-)
Also, the inrush current test results have now been posted. You can find them here.
Give me some love.
Unread 06-11-2012, 07:52
Jared Russell's Avatar
Taking a year (mostly) off
Does the 888 have the same ~50Hz update rate that its predecessor did? What is the frequency of the modulated output?
Unread 06-11-2012, 08:02
I've been told by a very reliable source that the output PWM frequency is 1000Hz. That's responsible for the reduction in current ripple and the improved linearity.
I think the input PWM signal period remains at 17ms since I've not heard otherwise.
Unread 06-11-2012, 08:12
For reference, what are the output PWM frequencies of the 884, Talon, and Jaguar?
Unread 06-11-2012, 08:35
Output PWM frequency:
884......150 Hz
888........1 KHz
Jaguar....15 KHz
Talon.....15 KHz
Input PWM signal period:
884......10ms WPILib driver (default value)*
888......no WPILib driver yet
Jaguar...5ms WPILib driver (default value)*
Talon....no WPILib driver yet
all the motor controllers are capable of periods of 5ms or less
* this is info I've picked up from CD. I've not personally vetted it.
Last edited by Ether : 06-11-2012 at 15:28. Reason: new info from Paul & Mike & Joe
