Go to Post I would ask for Florida to take a vote on best team, but my fear of "Hanging Chad" in close decisions has not fully subsided. - IKE [more]
Unread 03-11-2012, 13:17
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Smartdashboard
This is my teams first real year using java and i was wondering where i might find files and tutorials relating to the smartdashboard
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 03-11-2012, 13:21
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Smartdashboard
http://www.youtube.com/watch?v=qnS6O04Yjrc
http://firstforge.wpi.edu/sf/docman/...root/doc1205/4
http://wpilib.screenstepslive.com/s/3120/m/7932
http://firstforge.wpi.edu/sf/wiki/do...iki/Extensions
Subversion repo address for SmartDashboard (requires a firstforge account to access): http://firstforge.wpi.edu/svn/repos/smart_dashboard
And there's also a small section in the WPILib cookbook on the SMTDB starting on page 56:
http://www.wbrobotics.com/attachment...ibCookbook.pdf
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 03-11-2012, 14:06
inkspell4's Avatar
Great thanks also do u have any programs i may be able to look at that use it
Unread 03-11-2012, 14:35
F22Rapture's Avatar
AKA: Daniel A
Re: Smartdashboard
What do you mean? Extensions, or robot code?
- Wernher von Braun
Unread 03-11-2012, 19:09
inkspell4's Avatar
Robot code
What do you mean by extensions
Unread 03-11-2012, 19:25
F22Rapture's Avatar
AKA: Daniel A
Re: Smartdashboard
Originally Posted by inkspell4 View Post
Robot code
SmartDashboard allows you to make extensions that can do different things. If you wanted to, you could easily create alternates to the dials and meters that are shipped with the smart dashboard, and to do that you would just make an extension, compile it, and put it into the C:\Program Files\SmartDashboard\Extensions directory. There was one team last year that made an extension which used sensors on their ball lift to detect where the ball was and then it would draw an icon for the ball over a picture of the robot on their dashboard.
The most common use of SmartDashboard extensions is vision processing. So the video feed gets transferred from the robot to the driver station over networktables and then the driver station pc does the actual processing, and then it sends the information back to the robot to be used for tracking or however it was programmed.
To answer your question I think the majority of the links I posted deal with the robot-side code.
- Wernher von Braun
Unread 03-11-2012, 22:07
inkspell4's Avatar
I was thinking more of example code that i could play around with and see exactly how it works
Unread 03-11-2012, 23:25
F22Rapture's Avatar
AKA: Daniel A
Re: Smartdashboard
You mean the source code? It's linked in the subversion repository in my first response. Go into Netbeans and then Team>Subversion>Checkout> then use that URL along with your firstforge account info.
And then the javadocs and source code for the robot side of smartdashboard are in zip files in the sunspot plugins folder in C:\Users\[username]
- Wernher von Braun
Unread 19-11-2012, 22:23
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Smartdashboard
There is a brief guide to getting everything up and running here:
http://team2168.org/index.php/resour...smartdashboard
It is meant to be a supplement to the WPI documentation (to answer some of the questions I still had after reading it).
This was for the 2012 season. There will be some changes made for the 2013 season.
http://team2168.org
