Go to Post Students, mentors, schools, corporations, teams, and communities - they are all critical to the success of FIRST. . - dlavery [more]
Unread 06-01-2003, 07:09
JamesJones JamesJones is offline
#0180 (SPAM)
JamesJones is an unknown quantity at this point
Bosch Pinion
Does anyone have the specs on the drill motor pinion (pitch dia, and pitch or module?)
Joe...save us!
James
Engineer/Coach
Team 180 SPAM
Unread 06-01-2003, 11:07
President, VEX Robotics, Inc.
Bosch Pinion Numbers
The Bosch pinion is still metric. It is a Module 0.7 [mm/tooth) with 15 teeth. The pitch diameter is 10.5mm (Pitch Dia = # of Teeth* Module). The module is the same as previous years, just a different number of teeth.
Edit: I have been digging deeper and the module may not be 0.7, but it might be 0.75. I will confirm tonight and post my findings in the morning.
Unread 10-01-2003, 16:59
#0180 (SPAM)
uh oh
Paul, please tell me it is .7
James
Engineer/Coach
Team 180 SPAM
Unread 10-01-2003, 17:16
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Heck with that gear
Oh, phooey on that gear... our team has decided to take the gear off and put on one that fits our geartrain better. I hope that a tight press fit works.
Andy B.
Unread 10-01-2003, 18:25
It is 0.7
It is a 0.7 module gear. It has a very long addendum (long teeth), but will work well enough for our purposes.
Andy,
Be very careful putting the gear back on. On last year's motor it was easy to take off the pinion, but I went through some motors putting on that darn new pinion.
-Paul
Unread 13-01-2003, 01:31
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
#0824 (SWAT Robotics)
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
Okay - newbie question: How *do* you go about removing a gear pinton like that one without damaging the motor? Do you heat the thing up, etc?
Unread 13-01-2003, 07:02
Matt Reiland's Avatar
'The' drive behind the drive
In the past we have used a press and a small 'punch' to press off/on the pinions on the motors, I would not recommend any thing that shocks the armature (aka hammer)
B.T.W (I am currently our of town) does anyone have for sure the number of teeth on the bosch motor, Paul you put in your post 15?
Unread 13-01-2003, 08:13
15
Matt,
You're right (and so is Paul)... 15 teeth on the Bosch Drill motor.
Andy B.
Unread 13-01-2003, 10:41
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
One other quick question:
The new Bosch drill pinion is still 20° pressure angle, right? (Like last year's.)
-Tristan Lall
Team 188, Woburn Robotics
Unread 15-01-2003, 06:52
Related question: Where do you buy metric gear tooth measurement devices? I am assuming you're using a gear tooth gauge - and I can only find one that measures in DP on MSC Direct. DO you just line it up to the gear and see which one fits the best? Thanks!
-=- Terence
Unread 30-01-2003, 00:15
Re: Heck with that gear
Andy B.
OK... we just took off that drill pinion today and put on a new pinion that was a 32 dp gear. After ruining one motor (bent the shaft a bit - too tight ID at press), we had some success in putting this new gear on.
Our new gear had a purchased ID or 0.187". First, this gear was drilled out with a 0.189" dia drill, and then a 0.191" dia drill. I'm guessing that this gives us an ID of 0.192" or 0.193" (we don't really have a precice way to measure this).
At this point, the gear presses nicely onto the drill's 4.99-5.00mm shaft. We are estimating that this provides a ~0.003"-0.004" press fit, which should be plenty tight in order for it to stay in place (no welding or pinning needed).
It "feels" right so far, but we won't know if it's right until it's put under a load.
Andy B.
Unread 30-01-2003, 09:28
Too tight of press
Andy,
.003" to .004" is too tight a press fit for that shaft. I pulled off the pinion and measured it with gauge pins and the original press is .0015" which is plenty for the amount of surface area you have on that pinion. My initial calcs with just a .001" press is it can handle 3x the stall torqu of the motor. We bent several shafts last year because our press was too tight.
Just some food for thought.
-Paul
Unread 30-01-2003, 09:45
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Also for CIM
I agree with Paul. A .001 interference is pleanty for such a small torque. In fact we also slid a pinion on the CIM motor with just .001 interference. No need to use the keyway or collars and the keyway slot provides some extra grip.
BTW, just heat the new pinion and it will slide on fairly easily. Just make sure to heat the tool that is holding the pinion and move quickly. Otherwise it will shrink and freeze in place as soon as it touches the shaft.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 30-01-2003, 10:11
Thanks
Paul, Raul,
Thanks for the feedback. Maybe I'm overestimating the amount of press fit interference we are getting. Possibly the hole we are drilling with a 0.191" bit is coming out bigger than I thought.
The gears that are getting drilled out are getting pressed on fairly easily and the motor turns like it did when it came out of the box... so it seems right so far.
Andy B.
Unread 22-02-2003, 03:05
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
what are the specifics of the gears you guys are using to press onto the drill motor?
we were trying to figure out what would be a good size to replace the metric gear that it currently has
I assume you guys are gearing these motors down to match speeds with the atwood? Something like 18/5 to gear it down? what gear tooths, pitches, and degrees did you guys use to reduce the output?
I am trying to take as many notes as possible in my free time i have now to use next year when we design our motor mounts (hoping we have the same drill motors, but for expirience none the less)
thanks alot!
TC
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Trade - have Bosch gearboxes, need motors Andy Baker Motors 0 24-01-2003 08:32
BOSCH motor pinion pitch Matt Reiland Technical Discussion 2 10-01-2003 09:26
Chiaphua gearing (Chippy and Bosch) honky Motors 3 31-01-2002 10:28
Bosch Extrusion Tony G. Technical Discussion 4 11-01-2002 19:04
Bosch Extrusion Tony G. Technical Discussion 0 10-01-2002 10:26
