Go to Post I don't think that FIRST is going to get better with a top down solution alone, it is going to take a grass roots effort to strengthen teams. That starts by teams getting off their "islands", self imposed or otherwise. - Fe_Will [more]
Unread 05-11-2012, 19:30
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: 3D Printer Recomendations
What G-code generator are you using? We use ReplicatorG and can set speeds there. It is pretty easy if you know where. Other programs will be different.
ChrisH
Originally Posted by JesseK View Post
Aluminum pullies. There seemed to be a fine line between just tight enough to print and so tight that the plastic around the idler pulley warps during printing. If there were a way to set the max speed of movement we'd be fine -- the belts only slip when there's an immediate high-speed reversal of the 'Y' motor (coincidentally, also the hardest motor to tension).
Christopher H Husmann, PE
"Who is John Galt?"
