Go to Post We considered naming our 2014 robot "Please Don't Point it at Me". I think the name fits. - KosmicKhaos [more]
Unread 05-11-2012, 14:51
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Retainer Ring Shaft Tolerance
When designing retainer ring grooves on shaft ends, do you add a little extra tolerance on the shaft length to make it easier to get on-off and provide a little freeplay? For a 1/2" retainer ring (0.035" thick), McMaster recommends a 0.039" groove width. Is this 0.004" enough?
Unread 05-11-2012, 15:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Retainer Ring Shaft Tolerance
I typically do just wide enough for it to reliably seat, and not any wider than that. To get them on easily, we typically chamfer the end of the shaft.
Unread 05-11-2012, 23:21
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
+1 point for that simple step.
Unread 06-11-2012, 00:06
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I've never had trouble with the tolerances being off. I've certainly cut the rings too deep, and had rattley snap rings, but I've never had any trouble assembling them because I was under the correct dimension in terms of width. On the other hand, we don't cut many snap ring groves.
We've just got a cutoff tool that was specially ground down to be the exact dimension of a snap ring grove. It's saved us a ton of work.
-Plutarch
Unread 06-11-2012, 00:10
AdamHeard's Avatar
Lead Mentor
We have an addiction to snap rings.
We have a grooving tool for each specified snap ring width, and haven't ever had problems with that.
Unread 06-11-2012, 00:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
If the ring matches one in a table in Machinery's Handbook—which it does—I'd just go with whatever tolerance they list. In this case the standard is MS 16624; I'd be completely unsurprised if McMaster was quoting its dimensions from that specification.
Originally Posted by Machinery's Handbook, 26th edition, page 1683
Source: Industrial Retaining Rings, 3100 Series. All dimensions are in inches. Depth of groove d = (DG)/2. Thickness indicated is for unplated rings; for most plated rings, the maximum ring thickness will not exceed the minimum groove width (W) minus 0.0002 inch. Standard material: carbon spring steel (SAE 1060-1090).
Ring Free Diameter Tolerances: For shaft sizes 0.125 through 0.250, +0.002, −0.004; for sizes 0.276 through 0.500, +0.002, −0.005; for sizes 0.551 through 1.023, +0.005, −0.010; for sizes 1.062 through 1.500, +0.010, −0.015; for sizes 1.562 through 2.000, +0.013, −0.020; for sizes 2.062 through 2.500, +0.015, −0.025; for sizes 2.559 through 5.000, +0.020, −0.030; for sizes 5.250 through 6.000, +0.020, −0.040; for sizes 6.250 through 6.750, +0.020, −0.050; for sizes 7.000 and 7.500, +0.050, −0.130.
Ring Thickness Tolerances: For shaft sizes 0.125 and 0.156, ±0.001; for sizes 0.188 through 1.500, ±0.002; for sizes 1.562 through 5.000, ±0.003; for sizes 5.250 through 6.000, ±0.004; for sizes 6.250 through 7.500, ±0.005.
Groove Diameter Tolerances: For shaft sizes 0.125 through 0.250, ±0.0015; for sizes 0.276 through 0.562, ±0.002; for sizes 0.594 through 1.023, ±0.003; for sizes 1.062 though 1.500, ±0.004; for sizes 1.562 through 2.000, ±0.005; for sizes 2.062 through 5.000, ±0.006; for sizes 5.250 through 6.000, ±0.007; for sizes 6.250 through 7.500, ±0.008.
Groove Width Tolerances: For shaft sizes 0.125 through 0.236, +0.002, −0.000; for sizes 0.250 through 1.023, +0.003, −0.000; for sizes 1.062 through 2.000, +0.004, −0.000; for sizes 2.062 through 5.000, +0.005, −0.000; for sizes 5.250 through 6.000, +0.006, −0.000; for sizes 6.250 through 7.500, +0.008, −0.000.
(All dimensions in inches; emphasis added.)
So, if you stack up the tolerances of the ring and the groove, it looks like they recommend quite a tight fit in terms of end play.
Realistically, it shouldn't matter too much, as long as you're not loading the ring anywhere near its limit. Your case for sacrificing a bit of load capacity for ease of assembly is probably a good one, in that case. If this was holding a wheel on, I would follow the specification carefully.
Unread 06-11-2012, 01:02
ttldomination's Avatar
Sunny
I suppose, on a smaller note, what's the rule/recommendation for the amount of material that ought to be left at the end of the shaft? I'm reading ~.05", but not sure what other FIRSTers use.
- Sunny G.
Unread 06-11-2012, 01:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'm reading the question differently than most.
It sounds like the OP is asking "Should I add some small amount of clearance to my width between snap rings so when I assemble everything the parts aren't stacked line to line between the rings?"
The answer to that is yes. Your tolerance stackup will inevitably lead to it being impossible for you to get the 2nd snap ring on without some slop.
You do not want that slop to be in the groove though. You should cut the groove .039 like McMaster says. Just add in .005-.010 to the distance between grooves.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-11-2012, 11:28
Yes this is what I was looking for... thank you! I should have been more clear... my example is that we are designing a new transmission and the tolerance stack up of all the gears, sprockets, bearings, frame, wheel, etc along the main output shaft may add up to the point that the end ring wouldn't fit. There is a spacer we could shave down to most likely solve any issues but wanted to avoid having to machine a longer output shaft. We then started to wonder about the tolerance stack up for a simple WCD axle (sprocket, bearings, wheel, etc). I couldn't find any manufacturing tolerances for most of the parts to make an estimation of what a worst case would be. 0.005-0.010" sounds good.
Unread 06-11-2012, 11:40
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Here is a tip when assembling our transmissions. We use fiber washers as shims to get the spacing just right between parts on a shaft.
http://www.mcmaster.com/#fiber-washers/=k1pki7
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 06-11-2012, 12:20
Originally Posted by roystur44 View Post
Here is a tip when assembling your transmissions. We use fiber washers as shims to get the spacing just right between parts on a shaft.
We were thinking of using a laminated washer like:
http://www.mcmaster.com/#round-laminated-shims/=k1q52f
Does the fiber hold up well? Maybe adds a little give?
Unread 09-11-2012, 09:02
President, VEX Robotics, Inc.
My absolute favorite for handling the slop take-up is a wave washer. Industrial robots use them everywhere in their gearboxes and the premier industrial gearbox companies that sell to industrial robot companies all use them. The McMaster versions are located here: http://www.mcmaster.com/#wave-disc-s...ashers/=k375io
These work especially well for gearboxes using spur gears.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
