Go to Post Blowing out the transmission on your mini-van while hauling a trailer 700 miles from home is not fun. Trust me on this. - dlavery [more]
Unread 06-11-2012, 11:12
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Chain length calculator
I'm wondering what teams use to calculate the correct center spacing for sprockets when an idler isn't used. Obviously this is trivial if the sprockets are the same size. It gets more difficult if the sprockets are different sizes, and when you realize that a sprocket is not a circle, but a polygon. For several of our mechanisms last year we used short runs of 25 chain, and tried to design in the correct spacing with Dr Joes chain path spreadsheet. Unfortunately, the chain was loose in every case.
I recently compared Dr Joes spreadsheet result with several online calculators, and they all came up with a center spacing that was larger. On one of the pages, it explained that a simple calculation assumes the chain follows a circular path around the sprocket, but this introduces some error. A better method assumes the chain rollers will be at the sprocket pitch diameter, but they are connected with straight lines, not arcs. For simple chain runs, I'll try this method in the future, but the great thing about Dr Joes tool is you can use more than two sprockets, and it shows a graphic representation of the chain path. Does anyone know of other tools out there that can do this? Should I ask Dr Joe for an upgrade?
Unread 06-11-2012, 13:15
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: Chain length calculator
Martin Gears & Sprockets gives a lookup table for chain lengths as a function of center spacing and sprocket sizes (approximation) and center spacing as a function of chain length and sprocket sizes (more accurate).
http://www.martinsprocket.com/2001/SecEc.pdf (page 17)
Unread 06-11-2012, 13:47
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
I know our team has used this is the past.
http://www.botlanta.org/converters/d.../sprocket.html
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 06-11-2012, 15:06
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Let me quote myself from here...
http://www.chiefdelphi.com/forums/sh...03#post1090203
You can also use the excel spreadsheet from that post to assist you.
Originally Posted by Phalanx View Post
If you use the correct length of chain and have your sprockets properly spaced you can typically avoid using tensioners, half links, and even master links (with the right chain breaker tool and technique) altogether. However, it is still wise to prepare to have a tensioning method available, as well as Master Links, and Half Links for quick fixes.
How do you find the right length of chain to use? There actually are formulas to help you figure this out.
Ideally you want to use only whole links and the total number of links should be a whole even number, ex.... 16, 18, 20, 22.....
Chain pitch is either .250 (#25) or .375 (#35)
Formula for Center to Center Distance of Sprockets:
(B1/8) * (2*B4-B2-B3 + SQRT((2*B4-B2-B3)^2-(8/3.14159^2)*((B2-B3)^2)) )
B1 = chain pitch
B2 = Sprocket 1 teeth
B3 = Sprocket 2 teeth
B4 = # Whole Links
Formula for Number of WHOLE Links:
(2*E4/E1+E2/2+E3/2+((E2-E3)/(2*3.14159))^2/(E4/E1))
E1 = chain pitch
E2 = sprocket 1 teeth
E3 = sprocket 2 teeth
E4 = Center distance
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 07-11-2012, 11:00
FRC #0610 (Coyotes)
Thanks everyone for the input. I made a quick spreadsheet using the formula provided in the Martin Sprocket and Gear document, and it seems to match various online calculators I have seen. For our application, it gives a center distance about 0.010" greater than Dr. Joes spreadsheet. Would this have been enough to take out the slack in our chain last year? I don't know, but I'm sure it would help.
My understanding is that the formula most people use is still an approximation.
This page here alludes to a more accurate method:
http://www.islandpondrailroad.com/chain.htm
It gives me a center spacing that is 0.015" greater. I know we are splitting hairs at this point, but I figure the more accurate the spacing, the less need we'll have for tensioners.
Unread 07-11-2012, 15:39
.010 extra in length at about 12 inch centers gives .212 sag in the chain at midspan if I did the math right (using 12 for the linear distance and 12.010 for the arc length).
Unread 07-11-2012, 17:25
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
If you use Inventor, the Design Accelerator will also allow you to verify dimensions for chain and sprockets. Having never used SolidWorks, I can't speak for it, but it's the kind of thing I'd be surprised it doesn't have.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
