Go to Post If you see Navy ships in port, you're going to be fine. If you see ships pulling out, or no ships at all, go East. Fast. - Matt Howard [more]
Unread 06-11-2012, 10:44
President, VEX Robotics, Inc.
Re: paper: Talon, Victor884, Victor888, and Jaguar speed vs torque tests
There seems to be some confusion regarding the input PWM signal period that VEX Robotics published. The 17ms input signal period in our documentation for the Victor 884 was the typical number used on the old IFI control system.
Both the Victor 884 and 888 can support (and has been tested to support) down to 2.1ms.
Sorry for the confusion.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 06-11-2012, 11:02
Thanks for the info Paul. For completeness, do you know the minimum period that the Jag can support?
Unread 06-11-2012, 12:15
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Unless Paul's team have changed it, the minimum PWM period for Jaguars is 5 ms (i.e. 200 Hz). This coincides with the cRIO capabilities. Jaguar was designed to work specifically with the cRIO for FIRST.
A period faster than 5 ms is great, but doesn't provide any benefit for FRC applications (unless jhersh updated the FPGA and I didn't get the memo).
-Scott
Unread 06-11-2012, 12:24
Scott,
We did not change it. It is still 5ms.
All,
To be clear, we did not do anything new with regards to the PWM input on the Victor 888. It has always been 2.1ms on the 884, but we just did a bad job documenting that fact.
Paul
Unread 06-11-2012, 12:27
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
The Talon input is interrupt driven so it can be updated at ~2.1 ms. We published 3 ms to add conservatism for variations due to calibration points and non standard pulse widths.
If the input pulse produces a rising and falling edge the Talon will process it.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 06-11-2012, 12:40
Originally Posted by Paul Copioli View Post
All,
Paul
Paul, would it be useful to ask the folks at WPILib to change their 884 (and future 888) driver to use a period of 5ms instead of 10ms? I realize it probably makes little difference in the vast majority of cases, but there may be teams who want to close a loop at 10ms.
Unread 06-11-2012, 13:12
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Paul, would it be useful to ask the folks at WPILib to change their 884 (and future 888) driver to use a period of 5ms instead of 17ms? I realize it probably makes little difference in the vast majority of cases, but there may be teams who want to close a loop at 10ms.
The current PWM setup in WPIlib (at least in LabVIEW) is a PWM output with a 5s period and a 'period multiplier' of 1,2 or 4. It's enumerated, so 1x, 2x, and 4x correspond to 0,1,2 respectively (I don't think you can add more multipliers if you want).
The Jaguars use a period multiplier of 1, for a 5ms period. The Victors use 2, for a 10ms period. Servos use 4, for a 20ms period, and raw PWM channels can use whatever they want (of the three choices).
All it takes to add a new motor controller (in LabVIEW) is to duplicate one of the Open blocks and change the scaling and period multiplier parameters. The Write and Read blocks will adhere to the scaling set in the Open block, and the drivers will use the period multiplier set as well.
However, the fact that the driver (in LabVIEW) uses uint8's to store full-range pulse position, so the uint8 stores the widest pulse that the library can generate and devices using a narrower range perform the scaling before converting to uint8 essentially makes the uint8 sent to the fpga the bottleneck for resolution on the entire pwm output system. So, added input resolution on any new devices (e.g. 10bit internal vs 12bit internal) makes no difference due to the 8bit limit of the library.
Looking at the library (specifically WPI_PWMConvertDeadbandMillisecondTimeTo8Bit) it looks like the u8 is a number of DIO loop ticks to hold the pulse high, and the DIO loop runs every 261 ticks of the main clock (40mhz). That would make 40mhz/261ticks the smallest interval of a pulse change possible in the fpga.
I could be wrong, but that's what I get from reading the LV code.
Kettering Motorsports
Unread 06-11-2012, 13:41
The Victor 884 class runs at 10ms. It's hard to tell from the comment if it was tested at 5ms.
     * kDefaultPwmPeriod is "ticks" where each tick is 6.525us
     * - 20ms periods (50 Hz) are the "safest" setting in that this works for all devices
     * - 20ms periods seem to be desirable for Vex Motors
     * - 20ms periods are the specified period for HS-322HD servos, but work reliably down
     *      to 10.0 ms; starting at about 8.5ms, the servo sometimes hums and get hot;
     *      by 5.0ms the hum is nearly continuous
     * - 10ms periods work well for Victor 884
     * - 5ms periods allows higher update rates for Luminary Micro Jaguar speed controllers.
     *      Due to the shipping firmware on the Jaguar, we can't run the update period less
     *      than 5.05 ms.
     * kDefaultPwmPeriod is the 1x period (5.05 ms).  In hardware, the period scaling is implemented as an
     * output squelch to get longer periods for old devices.
Unread 06-11-2012, 15:00
Thanks for the correction. I will edit my previous post.
Unread 06-11-2012, 15:08
And it's as easy to change as calling setPeriodMultiplier in C++ and Java.
Unread 06-11-2012, 15:27
So the 884 could be run at 5ms. Do you know of any teams that have done this?
Unread 06-11-2012, 20:12
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
ether, can you share any info about the 888 such as operating voltage and amp rating?
My Instructables
Unread 07-11-2012, 00:38
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Victor 888:
Nominal Voltage: 12V
Min/Max Voltage: 6-15V
PWM Input Pulse: 1-2 ms
PWM Input Rate: 2.1-500 ms
PWM Output Chop Rate: 1 KHz
Fan Voltage Range: 6V - 16V
No max current listing yet.
We'll be testing one to determine max current (failure current) over the next week along with a Talon.
Unread 07-11-2012, 01:09
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Tom Line View Post
Victor 888:
Post video, or it didn't happen!
Unread 08-11-2012, 11:13
Links should be fixed now.
Here's an interesting visual. I wrote an awk script to read and convert the RPM vs Nm @ fixed IPW1 raw data into a family of closely-spaced RPM vs IPW @ fixed Nm curves and plotted it with gnuplot. You can really see the change in linearity of the 884 as the load on the CIM increases.
Also, FWIW, here's a graphic of the 884 driving a 1500 ohm resistive load. You can see how linear it is. The non-linearity (when connected to a motor) comes from the interaction of the (slow) frequency the 884's output with the motor's inductance.
1 input pulse width
