Go to Post Maybe FIRST could get a sponsorship from Ikea, and we all could get flat-packed field parts with pictoral assembly instructions. And then all the parts could have funny names. - sanddrag [more]
Unread 11-04-2012, 05:15 PM
toadoncart toadoncart is offline
FRC #3834
toadoncart is an unknown quantity at this point
motor reverse direction
how do i make my motors reverse direction if i'm programming in java? any possible references anybody could suggest? thx!!!
Unread 11-04-2012, 09:01 PM
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
It all has to do with the pwm value you pass to the motor (try making the value negative)
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 11-04-2012, 09:06 PM
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Re: motor reverse direction
It depends on what you're trying to do. If you're controlling a motor like motor.set(0.5), then you would change that to motor.set(-0.5). If you're using the output forom a joystick you should change something like motor.set(stick.getX()) to motor.set(-stick.getX()). Where motor is the motor you are inverting, and stick is the joystick you use to control it.
If you are using inverting a drive motor, it is a little different. You must use the setInvertedMotor method of robot drive. You would add drive.setInvertedMotor(kFrontLeft, true) for each of the drive motors you wish to change and would replace drive with the name of your robot drive object. If you only plan on running the motor in one direction, you could just wire the motor to the speed controller in a different way.
Unread 11-07-2012, 08:51 PM
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
If you're using the SetSpeed function, or whatever it's called now (it's been a few years), the values passed (-1 to 1) determines the speed, with 0 being stopped, 1 being full power one direction, and -1 being the opposite direction at full power. Try negating the value passed in to the controller to make the motor spin the other way.
Attending: MN Duluth Regional
Unread 11-08-2012, 01:50 PM
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
This belongs in the programming forum, not the motors forum.
It depends on how you're controlling the motor. The standard method takes a double between -1 and 1 to control the speed; -1 backwards, 0 stopped, 1 forwards.
What programming language are you using? What methods/functions are you using? Details like these would make it easier for us to help you.
Good luck.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
