Thread Tools |
Rating:
Display Modes |
Re: Can Jaguars
I'm fairly sure it does. However, be careful with CAN. It's been incredibly unreliable for us.
Re: Can Jaguars
Good luck! |
Re: Can Jaguars
The referenced how tos are good. So here is a list of hidden gotchas in CAN. Avoid them, follow the how tos & it works well. Other feel free to add to the list.
Bad wiring- make sure your cable connections are good. This includes crimps in the plug & the female connector on the Jag. Do not have strain on the connectors, but don't let the wiring flop loose either. Use terminating resistors. I not sure this is really needed in the short cable runs, but why tempt fate. Besides the first on the list of troubleshooting is to check the wiring. Avoid running can comm cables parallel to power wires, especially motors. Do not flood the canbus with commands. You can fill the bus up and have data drops. Make sure the programmers understand what the Jag really needs. Do not send commands to non existing Jags. The comm driver does not like that. Last edited by FrankJ : 08-11-2012 at 09:50. |
Re: Can Jaguars
I've also seen long busses with a 120ohm near one end and no other terminating resistor do really strange things with reflections (we had a node that was actually wired inverted and was reading the reflections instead of the actual message... that was weird) Bottom line: You need both resistors for reliable performance. On a short enough bus, you can get away with just one. Last edited by apalrd : 08-11-2012 at 11:27. Reason: Fixed terminating braket on quote |
Re: Can Jaguars
I guess you do need at least one resistor to make the voltage drop. A good point. Having one on each end is for reflections you do not see on short runs as you said. Also as you said, it is always best just to follow the spec which requires terminating resistors on the ends. I have borrowed a termination resistor off one end the canbus & did not see a difference. I would not try this in a competition.
People also get away with using star topologies, which in not in the specification. It has the advantage of not depending on the through jag connection although it makes for a lot more wire terminations & raises a question on where the resistors should be. Having not tried this, I do not have an opinion on how well it works. |
Re: Can Jaguars
http://www.can-cia.org/fileadmin/cia...icc/9/saha.pdf http://srv.uib.es/ref/838.pdf |
#7
Re: Can Jaguars
CAN uses differential signaling, and those termination resistors provide the proper load (60 Ohm DC) for the drivers as well as an impedance match (120 Ohm at each end of a nominal 120 Ohm transmission line) to limit reflections on the bus. While a short cable length might not need the termination from a reflection perspective, the drivers still need a proper load regardless of the length. The implication here is that you want a bus with the termination resistors at either end, and the shortest possible stub lengths (distance from the bus wire to the transceiver chip...which is some short distance on the Jaguar circuit board that you don't have to worry about). So, don't try to mitigate the single point of failure...if you don't have all of the jaguars in 'series' then all of the transmission line math breaks down and you'll have bus failures. For more gory technical details here's a TI application note that goes into the bus operation and termination particulars: http://www.ti.com/lit/an/slla270/slla270.pdf And here are Scott McMahon's videos on how to wire a Jaguar from TI (scroll to the bottom of the page): http://www.ti.com.cn/mcu/cn/docs/mcu...ntentId=100442 Don't ask me why it's on TI's china site, but those are definitely Scott's videos. |
#8
Re: Can Jaguars
I'd also like to point out that, as an expensive alternative (provided you have the funds), the 2CAN offers a much more sophisticated CAN interface than a serial-to-CAN can offer, and also provides better performance (if you don't plan to rely heavily on CAN during the season, you won't need its advantages - but it never hurts to know more!). With reference to the star topology that Ether mentioned, here's a backbone setup that you can try out for yourself. Good luck! |
#9
Re: Can Jaguars
Re: Can Jaguars
I agree that one failed Jag in the middle of the line won't usually cause problems for downstream Jags. But I've seen and heard of problems with the wiring, such as a connector breaking or coming out, and then all of the downstream Jags are out, plus often the upstream ones as well. A short circuit will usually disable all the devices on the bus.
I mention these only as a concern, and something to guard against. As I posted earlier, we've been very careful with our wiring, and we've never had any problem using CAN. |
