Go to Post Thinking about this game within the confines of previous years will limit you. - Gregor [more]
Unread 15-01-2003, 11:15
Geoff_494 Geoff_494 is offline
#0494 (Martians)
Geoff_494 is an unknown quantity at this point
Send a message via AIM to Geoff_494
Run the power from the batteries to the brown lead on the sensor, then connect the blue lead to the negative terminal on the battery, and also run a lead from the negative terminal of the battery to the ground pin on the Isaac 16 digital input (so you have 2 leads going to the negative terminal of the battery). This is important because the robot controller uses the ground pin to detect whether anything is connected on the input. Finally, attach the white or black lead (only one) to the input pin of the digital input, test these to see which one you want. (I think white is normally-on, black is normally-off). That should allow you to power the sensor externally but still have it operating as a digital switch for the robot.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
