Re: Controlling Vex 393s
Running a 393 off the DSC requires the placement of a jumper to provide power over the PWM and you still need the vex motor controller in line with the motor.
Question, Am I correct in assuming a regular 3 wire "old" VEX motor would work fine in this situation? |
I suppose this is a matter of using what they have laying around already to keep expenses non-existent. Last edited by Mark McLeod : 09-11-2012 at 07:26. |
I was specifically hoping to power it by paralleling 5V lines from the Teensy, a microcontroller that uses the Arduino language. Unfortunately, I hadn't actually checked any specs before asking, but seeing the specs on the motors now (7.2V, 4.8A stall), I'm rather reluctant to even try that theory out.
In any case, for curiosity's sake, how would the 393 be controlled by toggling a 7.2V power supply? Would it be the same type of pulse modulation used on regular motors, or does its construction require a different type of signal? |
It has a standard motor inside, so the same sort of on/off pulse modulation for a duty cycle is used to vary the speed.
