Go to Post Sleep is for the weak in week 6! - JesseK [more]
Unread 10-11-2012, 13:56
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
What's the verdict of on-robot cameras?
I remember seeing tons of videos from the robots perspective coming from teams who mounted a go-pro camera on their robot for every round.
What's the verdict out on this?
Is this allowed? Under what rule? Is it not recommended?
Just wanted to get a low-down so we know what the status of the situation is, as we're considering doing this.
Unread 10-11-2012, 14:01
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: What's the verdict of on-robot cameras?
done it.
http://www.youtube.com/watch?v=6RTgHKxjS3s
as long as it doesn't transmit it's fine.
Unread 10-11-2012, 14:16
Cameras can be part of the robot provided all other rules apply. Specifically but not limited to the following:
Must be weighed on the robot.
Battery must be fully contained within the camera and be isolated from the frame.
Camera must be securely fastened to the robot so as to not damage other robots, field or produce injury to volunteers or participants.
Camera cannot cause distraction to other drive teams.
Camera cannot transmit wireless without prior written approval of FIRST engineering staff.
As you can guess from the forgoing, the camera must be part of the inspection process.
Unread 10-11-2012, 15:06
ksafin's Avatar
AKA: Kirill Safin
Thanks guys, that cleared a lot up!
Unread 10-11-2012, 16:00
maddoctor90's Avatar
maddoctor90 maddoctor90 is offline
AKA: Matt
FRC #2481 (Roboteers)
maddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to behold
Did rule R14 "No individual item shall have a value that exceeds $400.00. The total cost of Components purchased in bulk may exceed $400.00 USD as long as the cost of an individual Component does not exceed $400.00" apply to cameras this past year or is there some way of getting around it? I think most teams I saw used cameras under $400. I am just curious since the only camera we have is not under $400.
Unread 10-11-2012, 16:36
ksafin's Avatar
AKA: Kirill Safin
What cams have you guys used?
I'm between strapping on just any member-owned camera and buying an MD80 (like a $13 chinese camera that's decent).
Unread 10-11-2012, 17:28
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I would be careful strapping on a camera worth more than $400 onto these robots if it's the only one you own. While the rules prohibit damaging another's robot, things do happen sometimes. I've seen plenty of broken pieces during my field reset days.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 10-11-2012, 20:43
AKA: Matt
I was more or less curious about the $400 rule applying then actually wanting to put our camera on the robot. The camera we access to is expensive because it is built for extreme industrial conditions. I think with a little common sense it would be fine.
Unread 10-11-2012, 22:22
synth3tk's Avatar
AKA: David Thomas
That makes a lot more sense, then. I just wanted to make sure you didn't duct tape your team's fragile reward from the last ten bake sales to a machine being put into a violent situation.
Unread 11-11-2012, 00:12
AKA: Ty
I lost my GoPro in the Atlantic ocean. smashed by robot is not as bad.
and cooler
Unread 11-11-2012, 00:17
Yes, it would apply. The camera goes through inspection with the robot, and is therefore to be considered as part of the robot. (Note: Just because the camera is considered as part of the robot does not mean it has to be present on the robot in every match.) As I recall, GoPros are less than $400--but the extreme industrial conditions camera probably would be a *little* bit more.
Unread 11-11-2012, 10:12
I see the cost limit a little differently. Since the camera we are discussing is generally not a permanent part of the robot and is used for recording only (not live video), I see it as a "non-functional" decoration. As a temporary decoration, it is hard to claim it must fit in the budget restrictions for functional parts of the robot. It is included in the weight since it does change that part of the robot when installed.
Unread 14-11-2012, 09:23
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Al,
Would you have any pull with the rules committee that might allow your view on this to be written into the rules? It would help eliminate any controversy during robot inspections.
I tried to mount a Kodak playsport on our robot two years ago, and was told by the lead inspector at the event that it would require a call to national headquarters to approve a special waiver.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 14-11-2012, 13:08
Todd,
I follow the GDC direction and the rules that they make. In this case there is some established guidelines. LRIs are trained to get in touch with me if they have questions. All of them will have my email and phone during the event season. Lacking contact with me, they also have other contacts that they should attempt to get a decision from, including my boss at HQ, and the the Director.
Unread 14-11-2012, 13:42
It appears that at least some Kodak Playsport cameras have wifi, which could cause the inspector to invoke [R67]. Additionally, the rules about devices with batteries were loosened last year.
