Go to Post Gotta love the blurred robots :cool: - Steven Donow [more]
Unread 11-11-2012, 01:32
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Re: CNC Lathes
Originally Posted by MICHAELABICK View Post
The only things that I can think of off the top of my head that would need a CNC lathe is a shifting block like the ones 254 uses and WCD output shafts if we got live tooling with the lathe.
That would be an operation done on a mill (CNC or manual) with a 4th axis with roughing/circlip-groves done on a manual lathe.
I can't think of any part that you would make for an FRC robot that couldn't be made on a manual lathe. The only advantage of a CNC lathe I can think of is the high turnaround time and the repeatability, but if you or anyone on your team has never run one before I can guarantee it will be a while before you gain either of those benefits.
CNC machines are not magical part producing machining, they require a lot of knowledge and expertise to operate. I would highly recommend that you spend your money elsewhere.
