Re: Drive Trains & All that they encompass
How do you know they aren't in the 2013 KOP?
Because it was announced that they would be Toughbox Minis (currently sold on AM).
Oh I missed that, where was it announced?
Because the 2013 Kitbot details were released in the FRC Blog back in September, at http://www.usfirst.org/roboticsprogr.../blog-09-07-12. Specifically the following section:
Now, some answers for the questions, from past experience: 1) Depends. KOP wheels, KOP with treads attached, modified COTS all have their uses. If I had a low budget, KOP or AndyMark; typically a 6"-8" wheel with 6" being preferred; larger wheels only if terrain required and I couldn't find another method. 2) 2"x1"x1/8" wall box aluminum extrusion, welded. 3) I've seen single speed (ToughBox equivalent), multi-speed (AM Gen2 and SuperShifter, as well as drill transmissions that came in the KOP before 2005). 4) See "other method" referred to in 1 above. 6WD or 8WD with dropped centers most likely, but terrain and other maneuverability requirements may call for something else. 5) Are you including the time for designing? KOP is 0 design, about half a day to a day building; custom drives can be 3-4 weeks designing and go together in two days or be 1 week designing and 1 day assembling mechanical stuff. 6) Chain, #35 to be exact, despite the weight. It's pretty good at staying on the sprockets and staying aligned. #25 as well for some applications off drive. 7) Long, but depends on the game as to what accommodations are made for acquisition. |
