Go to Post Just take a chance. Dream and live. It's not a wild decision, but just ask yourself - if I got my team just a little bit more spending money, where would my team be then? Then, change that dream into a reality. Help your team sustain itself to inspire more kids. - CalTran [more]
Unread 11-11-2012, 21:03
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
I need help wiring and programming a Gyro
Hey CD
Our team has decided to use a gyro, for the very first time
and i was wondering, if your guys can help me out of how to wire and program gyro in Java.
Much Thanks in advance
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 11-11-2012, 21:34
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: I need help wiring and programming a Gyro
Some explanation and example code in C++ and Java (pages 19-20) here:
http://www.wbrobotics.com/attachment...%20Guide. pdf
Wiring is covered here:
http://www.usfirst.org/sites/default...meter-Gyro.pdf
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 12-11-2012, 07:45
2185Bilal's Avatar
AKA: Bilal Majeed
Thumbs up Re: I need help wiring and programming a Gyro
Okay i understand how to program it, but please could someone expand on how to wire it.
Cuz i did not understand much from the document posted above
RAMAZOIDZ
Unread 12-11-2012, 17:21
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The gyro is an analog sensor that measures angular acceleration (how fast the rate of turning is changing with respect to the location of the gyroscope). As such, the gyro is connected to the analog breakout board by 3 wires: power, power return, and signal. The signal line is a voltage between 0V and 5V scaled to the rate of angular acceleration; this is what the "rate" pin in the wiring guide refers to.
In the pinout guide, you'll also have noticed that there are two sets of pins - rate and temperature. Temperature is included because changes in temperature can affect the output of the sensor that measures angular acceleration, but in FRC its impact is largely negligible. The one you care about is rate, because that's the one that will let your code determine angular velocity (how fast you're turning) and angular position (what angle your bot is facing).
So as a summary: The gyro ties into the analog breakout board. The +5V goes to the (+) pin (for power), the GROUND to the (-) pin (for power return) and the RATE to the signal pin, to give you the actual sensor feedback.
If you didn't get your gyro from the KoP, double check to make sure that it's analog; if not and it's digital, you want to tie it to the digital I/O pins on the sidecar.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
