Go to Post I'll toss this out to stir up the pot: if you need double precision floats for your FRC software, you should re-think what you're doing. - Ether [more]
Unread 12-11-2012, 12:59
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Java Code Deploying Help
Hey CD
we have recently decided to use Java to code our robot.
but here we have a problem:
everytime we build/deploy the code in Netbeans we get the following message
Waiting to Connect to OTA command server of 10.21.85.2:8001 for the past 10 sec
this message keeps going on and never stops
Would you please help us and tell us what should so or what we did wrong
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 12-11-2012, 13:10
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Re: Java Code Deploying Help
Netbeans deploys code by FTPing it into your cRIO. My guess is that you aren't making the network connection into the robot.
The first thing to check is whether your Netbeans is configured with your team number, since that will determine what IP address it's trying to connect to. Open the Netbeans preferences dialog and select Miscellaneous / FRC configuration to set it.
Next check that your computer is on the correct subnet for the cRIO. The subnet IP addresses are based on your team number.
If you open a command window, you should be able to "ping" or "ftp" straight to the cRIO. This will help diagnosing network problems.
Unread 12-11-2012, 13:12
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Are you sure that the robot is connected properly to your computer/laptop? If connecting times out, that probably means that it is not connected right. Make sure you've set the IP correctly.
All opinions are my own.
Unread 12-11-2012, 16:21
2185Bilal's Avatar
AKA: Bilal Majeed
Post Re: Java Code Deploying Help
Thanks very much, we fixed that problem but now a new message pops up.
This time when we deploy the code:
if does everything but it gets stuck on this line:
[cRIO] GCs: 1 full, 0 partial
[cRIO] ** VM stopped: exit code = 1 **
[cRIO] task 0xdaa8c0 (SquawkRobotTask) deleted: errno=0 (0) status = 1 (0x1)
The consol does not pass this line and gets stuck here
Could you please help me solve this issue
RAMAZOIDZ
Unread 12-11-2012, 16:30
AKA: Joel Gallant
That means that somewhere (I'm assuming in the WPIlibj or squawk), this is called.
System.exit(1);
If you could figure out what you're doing in your code that would cause to API to shutdown on you like that, you'll find out why that comes up. It's possible this might be something to do with how you deployed. (Did you image your CRIO correctly? Have you run java code on it before?)
Unread 12-11-2012, 17:10
2185Bilal's Avatar
AKA: Bilal Majeed
System.exit(1);
Well, for the 2012 season we were using Labview, but this year we decided to use Java. So today, I re imaged the cRIO to work in a Java Developing Environment and I also formatted the image. And we have never run java on the cRIO before.
The way we deployed the code, was basically connected to our cRIO using a direct ethernet cable, we opened the Driver Station program and it showed us that we had communication. Then we opened netbeans and pressed the green play button to deploy the code. It did all the stuff it shoudl (built the project, downloaded it, rebooted the cRIO) and then it stops at the line that i posted before.
I am not sure if this is a programming issue or electrical issue. and also if it would be helpful, i can post my code in this thread
RAMAZOIDZ
Unread 12-11-2012, 18:19
AKA: Joel Gallant
Sure, do that.
Unread 12-11-2012, 20:06
2185Bilal's Avatar
AKA: Bilal Majeed
sure here it is:
package team2185.code.exhibtionCode;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
public class ExhibtionCode extends IterativeRobot {
    // DEFINING THE JAGUARS
    Jaguar lm1 = new Jaguar(1); // left motor
    Jaguar lm2 = new Jaguar(2);
    Jaguar rm1 = new Jaguar(3); // right motor
    Jaguar rm2 = new Jaguar(4);
    RobotDrive driveSys = new RobotDrive (lm1, lm2, rm1, rm2);
    Joystick control = new Joystick(1);
    public void robotInit() {
        // INITIALIZATION CODE
        // code in here runs when the robot first starts up
    public void autonomousInit() {
        for(int i=0; i<4; i++){
            driveSys.drive(0.5,0);
            Timer.delay(2.0);
            driveSys.drive(0,0.75);
            Timer.delay(1.0);
    public void teleopInit() {
        // TELEOPERATED INTIALIZATION CODE
        // runs only once at the start of the teleop period
    public void autonomousPeriodic() {
        // called periodically during the autonomous period
    public void teleopPeriodic() {
        if (control.getRawButton(1)){ // if button 1 pressed drive at full speed
            driveSys.tankDrive(control, 2, control, 5);
        }else {                       // else drive at half speed
            driveSys.setMaxOutput(0.5);
    public void disabledInit() {
        driveSys.drive(0.0, 0.0);
RAMAZOIDZ
Unread 12-11-2012, 20:47
AKA: Joel Gallant
That code looks all right. Not sure of your intentions for it (A button to go full speed?), but from an error standpoint, it looks all good. If I were you, I'd reimage the CRIO and possibly reinstall the FRC plugins (Maybe compiling is going wrong and the bytecode won't run).
Unread 12-11-2012, 21:53
2185Bilal's Avatar
AKA: Bilal Majeed
Okay, I did that and I will try that out tmw in school.
Also is any other advice you can give me
RAMAZOIDZ
Unread 12-11-2012, 22:09
AKA: Joel Gallant
In this :
Make sure you setMaxOutput() back to 1 when the button is pressed. So,
            driveSys.setMaxOutput(1);
Unread 13-11-2012, 06:56
2185Bilal's Avatar
AKA: Bilal Majeed
I meant some advice that would help me to deloy the code. Could you like tell me how teams deploy the code and what should the ip address be of the pc and crio
RAMAZOIDZ
Unread 13-11-2012, 17:48
2185Bilal's Avatar
AKA: Bilal Majeed
Okay never mind
I got the robot running. Thanks for all your help, i really appreciate it
And also i will looking forward to see ur team at GTR West and east
RAMAZOIDZ
Unread 13-11-2012, 18:36
AKA: Joel Gallant
No problem.
I don't think our team is heading out there this year unfortunately. Maybe worlds.
