Go to Post Some clever fellow a few years back made a little scooter based on this principal and made so much on the idea he can afford the finest denim in the land. - phrontist [more]
Unread 15-01-2003, 14:09
deuceswild deuceswild is offline
#0192 (GRT)
deuceswild is an unknown quantity at this point
speed controllers & circuit breakers
I've heard that the speed controllers require a 40 amp circuity breaker. Is that true? Can we use 30 amps instead? If you can only use 40, that'd limit our # of speed controllers to 4, because you can only use 4 40amp circuit breakers. Thanks a lot.
hmm...i should think of putting something here....
Unread 15-01-2003, 14:40
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
newest team update says you can use 30A so i say go for it...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 15-01-2003, 14:46
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
40 amps
The motors that require a 40 amp breaker are the drills and CIMs/Atwoods/Chipuas whatever you call them. Since the 40 amp breakers have not shipped yet, you are allowed to use the 30 amp breakers until they come in. All other motors require other circuit breakers so read the manual to find out what goes where.
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
speed controllers archiver 2000 5 24-06-2002 00:19
circuit breakers.... archiver 2001 2 23-06-2002 23:58
Circuit breakers archiver 2000 8 23-06-2002 23:30
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
