Go to Post Imagine a world solely consisting of FIRST students. Oh the things that we could do. - Ryan Himmelblau [more]
  #121   Spotlight this post!
Unread 13-11-2012, 15:04
Re: New Talon Speed Controller
Originally Posted by Jon Stratis View Post
Of note, the data you gathered didn't seem to show this same result, which leads to a question of which data set more accurately reflects real-world usage on a FIRST robot.
The first graph you linked was using a Window motor, not a CIM, with unknown torque load.
The second graph you linked was using a CIM with unknown (and possibly changing) torque.
All the testing I did was with a CIM motor on a dynamometer with measured torque load.
So it's difficult to compare the data.
  #122   Spotlight this post!
Unread 13-11-2012, 15:19
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by Jared341 View Post
The AndyMark product page for the Talon (http://www.andymark.com/Talon-p/am-2195.htm) says something interesting:
"Do you want your motor to hold it's position after power is cut?"
How does the Talon provide this? Does it stay in brake mode even after power is removed?
That is correct, and we're verified it.
It stays in brake after pwm signal is removed.
Last edited by Tom Line : 13-11-2012 at 21:46. Reason: Edited to clarify my wording.
  #123   Spotlight this post!
Unread 13-11-2012, 15:21
AdamHeard's Avatar
Lead Mentor
It stays in brake after power is removed.
Is there still a jumper to enable/disable brake mode?
  #124   Spotlight this post!
Unread 13-11-2012, 15:24
Tom Line's Avatar
Yes there is.
However, one thing we didn't verify is what happens if the jumper is set to coast and the pwm signal is killed.
Mike C. can probably answer that without us doing another test.
  #125   Spotlight this post!
Unread 13-11-2012, 15:35
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Agreed!
Ultimately, graphs can only tell you so much... the real "proof" is what the drivers think when you stick some of these onto a drive train. I know when we switched from Victors 884's to Jaguars, there was a noticeable improvement in our ability to control the robot. Would there be a noticeable difference switching between Victor 888's, Jaguar's, and Talon's? Personally, I wish I had about $400 to spare so we could buy 4 Talons and 4 Victor 888's and swap them out on last year's robot!
2016: Lake Superior WFFA
  #126   Spotlight this post!
Unread 13-11-2012, 16:28
When you're trying to do closed-loop control of speed, you might want to see what the torque response vs command looks like at various speeds.
So I just wrote an awk script to re-arrange the raw RPM vs Nm data to provide a family of curves of Nm vs IPW1 at various RPM levels.
Here's the result:
http://ether.comeze.com/FRC/WMCT801/
1 input pulse width in ms
  #127   Spotlight this post!
Unread 13-11-2012, 16:50
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
The way I'm interpreting this is that, after the main breaker is switched off, dynamic braking still occurs (i.e. the output is still shorted). This is very different from saying that the behavior at a neutral command is to dynamically brake the motor.
Could you confirm that brake mode persists after the main breaker is switched off? This could become a serious issue when teams need to push the robot around by hand.
Also, if this really is the case (I'm skeptical), could someone answer how this (feature apparently?) was implemented.
  #128   Spotlight this post!
Unread 13-11-2012, 18:09
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Originally Posted by flameout View Post
The way I'm interpreting this is that, after the main breaker is switched off, dynamic braking still occurs.
I would not have interpreted it they way you have. I would have interpreted it as that when the PWM signal is disabled (flatlined) the Talon continues to apply brake mode if the brake/coast jumper is set to brake.
When the main breaker is switched off, power is cut to everything, including all Talons, Victors, and Jaguars. At that point, the MOSFETs in the H-Bridge turn off and the only conduction possible is through the reverse body diodes.
  #129   Spotlight this post!
Unread 13-11-2012, 18:14
AKA Ryan Van Why
FRC #0957 (SWARM)
That makes sense, and matches the behavior of every other FRC-legal motor controller.
This is why I'm skeptical -- and why I was curious to know how my interpretation is possible.
I'll assume your interpretation is correct, then, unless someone comes in and confirms that mine was correct.
Thanks for clearing that up.
  #130   Spotlight this post!
Unread 13-11-2012, 19:51
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
This is a misprint. It should read "when disabled" not "after power is cut".
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
  #131   Spotlight this post!
Unread 13-11-2012, 19:55
Scott, you are correct.
Mike Copioli
  #132   Spotlight this post!
Unread 15-11-2012, 14:42
Has anyone with a Talon trying to control it with a cRIO/WPILib found a set of PWM signal timings that work well? The source for the Victor notes that signal acceptance between units was a bit off and I was wondering if this can be attributed to the signal generator or consumer side. I have a feeling this can be chalked up to poor calibration on the Victor as the cRIO generating sloppy signals seems less likely.
If no one responds we will run a test across 4 Talons to find timings that work, then post the results here and to WPILib.
From Victor.cpp:
* Note that the Victor uses the following bounds for PWM values.  These values were determined
 * empirically through experimentation during the 2008 beta testing of the new control system.
 * Testing during the beta period revealed a significant amount of variation between Victors.
 * The values below are chosen to ensure that teams using the default values should be able to
 * get "full power" with the maximum and minimum values.  For better performance, teams may wish
 * to measure these values on their own Victors and set the bounds to the particular values
 * measured for the actual Victors they were be using.
 *   - 210 = full "forward"
 *   - 138 = the "high end" of the deadband range
 *   - 132 = center of the deadband range (off)
 *   - 126 = the "low end" of the deadband range
 *   - 56 = full "reverse"
  #133   Spotlight this post!
Unread 15-11-2012, 15:06
Using a custom PWM signal generator, I have run the Vic888 with periods from 5ms to 20ms, and with pulse widths from .5ms to 2.5ms with no problems. I believe I did the same with the Talon, also with no problems.
[edit] I have not tested whether the motor controllers would calibrate properly to this pulse width range [/edit]
  #134   Spotlight this post!
Unread 15-11-2012, 16:06
[edit]
Just calibrated an 888 driving a 500 ohm resistive load. Calibrated to 2.000 ms max, 1.000 ms min, and 1.500 ms neutral. Then measured, and got 1.990 ms max, 1.021 ms min, and deadband from 1.482 ms to 1.523 ms
[/edit]
The problem that the comment that Tom is referring to was finding what values work best with factory default calibration, and with the Victor 884, it varied unit to unit.
  #135   Spotlight this post!
Unread 15-11-2012, 16:54
FWIW. Vic888 calibration using 500 ohm resistive load.
