Go to Post You know those gravitational waves you keep hearing about recently? Those weren't created by colliding black holes, they were created by our boulders colliding with the opposing alliance's tower. - JohnFogarty [more]
Go Back   Chief Delphi > Other > FIRST Lego League
Unread 13-11-2012, 20:29
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
Senior solutions: the bowling mission
i mentor a team for FLL and i was wondering if for bowling your robot can throw the ball (like catapulting it). i know the physical people can't.
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 13-11-2012, 21:53
399thegeneral's Avatar
399thegeneral 399thegeneral is offline
AKA: Jackie
FRC #0973 (The Greybots)
399thegeneral will become famous soon enough
Re: Senior solutions: the bowling mission
Originally Posted by Page 14 Robot Game Manual
METHOD RESTRICTION:
— Each pin’s fall must be caused by impact from a completely loose and independent ball (not touching or guided by anything at the time of impact) or another loose/independent pin. Pins falling for any other reason are worth 0.
As long as it's only the ball that knocks down the pins you should be fine.
www.greybots.com
Unread 13-11-2012, 22:13
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
If you look at the rules and read them carefully, you will see that yes if the robot throws the ball, that is legal. The rules do not specify how the robot moves the ball, only that the ball must be totally free at the time of impact with the pins.
Originally Posted by Official Rules
Bowling
Basic description: Robot sends balls to knock pins down. If the pins are not all down after the first try using a yellow
ball, the referee returns that ball to Base for a second try (this can only happen once per match).
Precise Scoring Conditions:
— 1 to 5 pins down: 7 each
— or —
— 6 pins down: 60
method restriction:
— each pin’s fall must be caused by impact from a completely loose and independent ball (not touching or
reason are worth 0.
Hope this answers your question, here's a link to the challenge if you need it: http://firstlegoleague.org/challenge...eniorsolutions
~Calvin
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 13-11-2012, 22:33
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
As a ref at a FLL regional a week ago the only criteria for counting the pins as scored was that the ball not be in contact with the robot when it knocked down the pins we did not care how you achieved this as long as the ball was "loose" of the robot.
Other competitions may offer different interpretations of this rule though so a good person to ask is the head ref at your competition.
2012-Present Wave Robotics Team 2826
Unread 14-11-2012, 09:07
jwalters1902 jwalters1902 is offline
FRC #1902 (4-H Exploding Bacon Robotics)
jwalters1902 is a jewel in the roughjwalters1902 is a jewel in the roughjwalters1902 is a jewel in the roughjwalters1902 is a jewel in the rough
If it is not the the robot rules, or in the updates, it is fine.
I would ask in the Coaches Meeting before the tournament begins. This way all the coaches can participate in the conversation on it.
Unread 14-11-2012, 10:44
I'm back
AKA: Matthew Lantry
thanks for the response
Matthew Lantry
Unread 01-12-2012, 01:33
budman budman is offline
FTC #9010 (Robotic Rangers)
budman is an unknown quantity at this point
Yes, the robot can catapult the ball from anywhere...including the base. This is clarified in rule update #12 entitled "bowling distance".
Here is a link to the rule updates:
http://firstlegoleague.org/challenge/robotgameupdates
