Go to Post Are you prepared to be a team member? - JaneYoung [more]
Unread 14-11-2012, 14:00
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: What's the verdict of on-robot cameras?
For Gopro cameras the Wifi capability is an addon that can be removed for field usage. Otherwise it allows you to control the camera with a smart phone or even stream video.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 14-11-2012, 14:24
Here is pertinent 2012 season Q&A. The add-on camera would have counted as part of the total robot cost.
This is the only direct reference I found.
Unread 14-11-2012, 14:29
eliman47's Avatar
eliman47 eliman47 is offline
FRC #3374
eliman47 is an unknown quantity at this point
I lost my go-pro skiing, getting it crushed by a robot is WAY cooler n that
Unread 14-11-2012, 14:31
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
The models we use are storage to SD card only. It's good to know we'll be able to shoot video this season. We were up against the budget cap last season, so we would not have been able to slip a camera onboard.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 14-11-2012, 16:25
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
From a common sense point of view:
On board cameras during real competitions provide a great public relations aspect to promoting FIRST and FRC. My thoughts:
  • Restrictions on WiFi are certainly reasonable
  • Restrictions against using the recorded footage for a competitive advantage within the same competition are reasonable (but hard to enforce, like many other rules.)
  • Including camera in bot weight, height, volume limit is reasonable
  • General safety considerations are reasonable
  • Disallowing due to battery is unreasonable
  • Disallowing due to budget limitation is marginal, but this should not usually be an issue anyway, since cameras can be had for <$400.
Of course the GDC's answer is final, but I would hope the rules are arranged so that we don't have to jump through hoops like getting waivers to get good video, like our Duluth Double Shot:
https://www.youtube.com/watch?v=i2KIVicKIOk
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 18-04-2013, 09:23
Generator of Entropy
FRC #2973 (The Mad Rockers)
Most of the discussion I've found from searching deals with using cameras for recording for post-match use. But it doesn't appear that there are any limits (other than those mentioned to pass inspection) regarding using something like a smartphone as a camera / processor for image processing and tracking and then feeding that information to the cRIO. Assuming we can find a smartphone for <$400, is it legal to use it as a custom circuit?
Also, regarding the $400 limit, I assume it would need to be the cost without an associated data plan subsidy which makes them pretty expensive; however, since refurbished phones are so readily available for <$400 (especially older models), what do you think about using the advertised cost from OEM's or major re-sellers of a non-subsidized refurbished phone as the cost for accounting purposes?
Unread 18-04-2013, 09:48
pathew100 pathew100 is offline
AKA: Pat Murphy
FRC #0862 (Lightning Robtics)
pathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud of
Send a message via AIM to pathew100
FYI, the latest generation of GoPro cameras (Hero3) has WiFi built in. It can be disabled (and must be on an FRC robot, obviously).
Unread 18-04-2013, 09:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Gary, those are great questions. I'd also throw into that mix -- how would you interface the phone to the cRIO? Seems like you may be able to get away with the cheapest/smallest Arduino setup possible that converts USB data packets to Ethernet packets ... but maybe you have something else in mind? Seems like you'd also have a great setup to siphon & store any images from the USB onto an SD card for post-match use.
A phone seems like the perfect self-contained processor...
GitHub
Unread 18-04-2013, 11:46
TedG's Avatar
TedG TedG is offline
CAD, Design & Graphics Support
AKA: Team supporter and enthusiast
FRC #0133 (BERT 133)
TedG will become famous soon enough
Originally Posted by Tytus Gerrish View Post
done it.
http://www.youtube.com/watch?v=6RTgHKxjS3s
as long as it doesn't transmit it's fine.
That was neat... made me sort of dizzy though
Bonny Eagle Robotics Team - BERT 133
2009-2010: Mentor, 2010-2013 Advisor/Mentor, 2013-Present: Mentor/Cad & Graphics Support
2010 - GSR: Excellence in Website Design
2011 - GSR: Motorola Quality Award
2012 - Mainely Spirit: Spirit Award, Human Player Award- GSR: Gracious Professionalism Award, Quarterfinalist- Beantown Blitz: Finalist
2013 - Mainely Spirit: Sportsmanship Award- GSR: Semifinalist, Woodie Flowers Award- PTR: Semifinalist- Beantown Blitz: Semifinalist
2014 - GSD: Spirit Award, 5th seed, Semi Finalists- PTD: 2nd seed, Finalists
2015 - Safety Animation 1st Place Award, PTD: Excellence in Engineering Award, 8th seed, Finalists, UNHD: Spirit Award, 9th seed, 6th seed Finalist Alliance Captain; Event Winner
2016 - NSD: Industrial Design Award, 3rd seed, Semifinalist- PTD: Excellence in Engineering Award, 2nd seed, Event Winner
Opinions expressed here are mine alone, and not necessarily of the team.
Unread 19-04-2013, 07:14
Gary,
I would view a phone as a custom circuit/outboard processor/computing device using it's own embedded battery under the robot rules as they stand. All wireless would have to be shown to be disabled to pass inspection as well as only providing power to a peripheral through the USB connection. As with any computing device/custom circuit, it must be weighed with the robot and be securely fastened. Duct tape is not a fastener for those thinking of easy solutions.
Unread 19-04-2013, 10:04
Thanks Al. Any thoughts on using refurbished phone prices for allowable cost?
Unread 19-04-2013, 15:40
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
Originally Posted by ksafin View Post
What cams have you guys used?
We use GoPro HD Hero Naked.
http://gopro.com/cameras/hd-hero-naked-camera/
Got an extra battery pack for the back and a 32 GB chip. That allows 4 hours of battery, and 6 hours of storage.
Looks like it may be discontinued, as GoPro.com does not carry it anymore. Great thing about the HD Hero Naked is that it is NOT wi-fi capable.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
