Go to Post Chain stretch debigulates drive train performance. - Richard Wallace [more]
Unread 13-11-2012, 23:20
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Camera Programming
So after three years, our team has finally decided to use a camera on the robot.
Since I was in the team three years ago, i dont have a single idea how to program the camera.
So I would like to ask the greater programmers at CD, to help me.
What do I need to program a robot to track the 4 squares (used in rebound rumble), and then move the robot so it aligns straight towards the target.
Like what electrical components do i need and how do I program a camera
thanks for the help
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 14-11-2012, 09:42
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Re: Camera Programming
Electrically, all you need is the camera (axis cam), an Ethernet cord to plug into your bridge, and the power cable wired to 5v on the Power Distribution Board.
For setting up and configuring the camera, refer to this document (search camera)
http://www.usfirst.org/sites/default...20System_2.pdf
There is a great write up on the vision targets here:
http://firstforge.wpi.edu/sf/docman/...ib/docman.root
With Java code examples and an explanation of the theory! (Read all the documentation and you will learn alot, if you have specific questions, ask them here and the community will help!)
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 14-11-2012, 20:11
2185Bilal's Avatar
AKA: Bilal Majeed
Post Re: Camera Programming
Okay thanks,
So I do have one question:
So here I have a snippet of the sample code given for Java programming:
//ColorImage image = camera.getImage();     // comment if using stored images
ColorImage image;                           // next 2 lines read image from flash on cRIO
image =  new RGBImage("/10ft2.jpg");
BinaryImage thresholdImage = image.thresholdRGB(255, 255, 0, 0, 0, 0);   // keep only red objects
BinaryImage bigObjectsImage = thresholdImage.removeSmallObjects(false, 2);  // remove small artifacts
BinaryImage convexHullImage = bigObjectsImage.convexHull(false);          // fill in occluded rectangles
BinaryImage filteredImage = convexHullImage.particleFilter(cc);           // find filled in rectangles
Now, the part that I have in bold, when I remove the "//" from the "ColourImage image = camera.getImage();" and comment out the other two lines. Netbeans gives me the error saying:
unreported exception AxisCameraException; must be caught or declared to be thrown
So what does this mean, and am I supposed to get this error, because I want to use my camera to obtain my image, not the sample images.
Also, I was just wondering. If I do happen to use the sample image, how do I get it on the cRIO. I know in the documentations it says, ftp to the root directory. But what does that actually mean, like how do i ftp to the cRIO, which software do I use and etc.
Thanks in advance
RAMAZOIDZ
Unread 15-11-2012, 15:17
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
camera.getImage() can cause errors (think about if you tried to fetch an image that didn't exist) so you need to surround it with a
try{
//getImage
catch (Exception e){
//insert code to log error here, if wanted
//handle the error by notifying the user to fix what ever is throwing the //error.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 15-11-2012, 16:21
2185Bilal's Avatar
AKA: Bilal Majeed
Okay thanks
But how do i download the sample images to the crio via ftp
Could u like tell me how to do it
RAMAZOIDZ
Unread 15-11-2012, 19:35
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
ftp://10.28.15.2/
Unread 15-11-2012, 23:14
~Cory~'s Avatar
Student
AKA: Cory Rypkema
FRC #0706
Use the address that cgmv123 posted (if you are using the default ip set up).
You can use FileZilla which has a graphic user interface or the default ftp
using a CLI FTP
Change to the current directory to the one with the image files
run ftp
type "open 10.28.15.2" and press enter
leave username and password blank
type "bin"
use the "cd" command to move to the directory that you want the files in
the use the "put" command to upload files.
corin.rypkema.org
WPI Class of '17
