Go to Post know what else would be great? with each new rep point you get 10 airline miles on your Visa or MasterCard - KenWittlief [more]
Unread 14-11-2012, 20:44
Butter's Butter's is offline
AKA: Joe Kent
FRC #0522 (Robo Wizards)
Butter's is an unknown quantity at this point
Cannot move robot
So, this has been an issue for a month now. The other programmers & myself are looking to switch to Java. We inherited C++ from the old programmer, but we are better in Java. Sadly, we can't get Java or C++ to work. I could care less if C++ works, I'm just looking for help in getting Java to run.
What makes this really annoying is...
  • Communication is fine.
  • RobotCode is on the robot (Deploys fine with netbeans).
  • Code is exact copy from the Java Starting Guide: Github link
  • Joysticks have a green light & respond on the I/O dashboard.
  • The jaguars stop blinking when we enable the robot (Which as far as I know means they are functioning).
  • Running latest netbeans plugins for FRC.
  • Teleop AND autonomous don't work.
  • Were not even using wireless, were wired in.
The cRIO is running on 2012_v43, and this is the only thing I'm not sure about (Is this latest?).
Things we have tried...
  • Restart the robot / change battery.
  • Re-imaged cRio.
  • Creating a new java project.
  • Different Java Code.
  • Change the joystick ports.
  • Prevented Windows firewall from blocking communications.
  • Pinging robot (Which works fine).
  • And other little things I forgot which we read online.
The only thing I wish to try is seeing if the compressor & piston work. If they do I know this is a jaguar/motor/electrical problem (Which doesn't make any sense, since we have not modified the robot mechanically or electrically sine last competition. And it worked fine then).
I'm literally clueless right now, for those interested, I even took pictures of all of it on my phone:
Link to photos
Any help would be awesome right now, I really want to practice with Java before the season starts!
Unread 15-11-2012, 02:54
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: Cannot move robot
What are the LEDs on the cRIO doing? Check the cRIO support PDF if you don't know what I'm talking about. Page 15 explains some of the different blink codes.
Mike B
Unread 15-11-2012, 10:25
AKA: Joe Kent
We are not having any blink codes on the cRio
Unread 15-11-2012, 18:11
SuperS_5's Avatar
FRC #1219
What do you mean by this? The driver station won't engage the tele-op or auto modes, or it engages, but does nothing?
Are there any error messages displayed in the driver station?
Mike B
Unread 15-11-2012, 18:33
Verify that you are downloading the program you think you are.
ftp to the cRIO and verify that the date of the Java program matches when you last downloaded it.
It sort of sounds like you're running a default program with different controls in it.
The Jaguars going solid mean they are being instantiated by the code.
Let us know if the Driver Station Diagnostics tab shows any messages.
Unread 15-11-2012, 18:45
AKA: Joe Kent
Will try this tomorrow / let you know the results.
Another words, I enable the mode via driver station, its on according to the driver station, but isn't doing anything.
Unread 16-11-2012, 14:07
AKA: Joe Kent
No error on console, and I was able to FTP into the robot fine. However, which directory is it in on the cRio?
Unread 16-11-2012, 23:10
thephpdev's Avatar
thephpdev thephpdev is offline
AKA: Josh Larson
FRC #2502 (Talon Robotics)
thephpdev is an unknown quantity at this point
A possible issue would be that your code throws an exception, or another error of sorts. Can you check your console window in netbeans to see if any error messages are being output'ed.
Unread 17-11-2012, 13:31
AKA: Joe Kent
No, there is no stack trace. Can someone answer my question still? Where can I locate the code on the cRIO after I FTP in?
Unread 18-11-2012, 14:53
AKA: Joe Kent
Huh, my original post didn't go through. Anyway, no stacktrace from netbeans. It builds & deploys fine. Can someone tell me where to look on the cRio? I went in via FTP but I have no idea where the directory is.
Unread 18-11-2012, 17:08
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Are you enabling the robot on the driver station? It was not enabled in the picture you posted.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 18-11-2012, 21:18
AKA: Joe Kent
Yeah we did, the picture of the DS was to show a green light for the robot code & communications.
Is anyone able to answer my question? Where is the code located on the cRIO?
Unread 19-11-2012, 03:44
SuperS_5's Avatar
FRC #1219
I just want to confirm that you have the cRIO modules in the correct locations.
The Getting Started PDF explains this on page 12. (Just trying to narrow things down)
Mike B
Unread 19-11-2012, 10:26
AKA: Joe Kent
As I said in my original post, the robot worked at our last event, and we have not modified it electrically or mechanically since then.
Also, can someone tell me where the directory is on the cRIO for the code. I was asked to confirm it's there but I'm not sure what directory it's in.
Unread 20-11-2012, 13:09
AKA: Joe Kent
Just tested the compressor, doesn't start either. I think the suggestion of default code being on the robot is correct, however, after I FTP in, what directory should I look in?
