Go to Post "Evaluate twice, execute once" - Andrew Schreiber [more]
Unread 17-11-2012, 00:56
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Thin wall 6061 aluminum tubing
Originally Posted by sanddrag View Post
Not true. In my opinion, 6063 machines terribly. It is somewhat "gummy". The chips like to melt to cutting tools and it's sometimes tough to get a nice surface finish. I try to avoid it when I can, but certain extrusions are not available in 6061.
Do you mean at certain speeds, you can melt end mills milling 6063? Would this be with cooling? I ask because one of those "certain extrusions" is what we're planning to use in our drive train wheel trucks. We would be pressing in bearings too.
-Plutarch
Unread 17-11-2012, 01:43
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
David is correct.
DampRobot (real name/team # would help), even with coolant and such. 6063 is gummy stuff. Its also weaker and will bend easier. You can easily crush it in a vise (while true with 6061, its a bit harder). I'd steer clear away from it.
What are you looking at that you can't get in 6061?
-RC
R.C.
MadTown Robotics Team 1323
Unread 17-11-2012, 06:53
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I believe this is because 6063 is rarely available with a strong temper/heat treatment. I have had the displeasure of post-weld machining 6061 with even worse results because it has nearly been annealed. 3003 and 1100 are also garbage to machine for the same reason I think.
Extra strong alloys, like 2024 and especially 7075, machine like butter in my experience.
Unread 17-11-2012, 07:11
Have you tried Westbrook Metals? Online they are Metals4U.com. I've had good luck with the Austin store, but wasn't purchasing aluminum.
Greg McKaskle
Unread 17-11-2012, 09:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Not melting the endmill itself, but melting the chips and fusing them to the endmill. You can machine 6063, but 6061 makes a much better chip and comes out much nicer.
Unread 19-11-2012, 16:07
Generator of Entropy
FRC #2973 (The Mad Rockers)
Both 6061-T6 and 6063-T6 are rated "C" for machinability by the Aluminum Association; it's likely a pretty broad range on the scale. I don't have any personal experience machining 6063-T6 so I'd defer to those who do.
Unread 22-11-2012, 22:38
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Greg McKaskle
I just found out last week that they have a Dallas store as well... I called them and while they don't have it in stock they are able to get it for me for a great price. They also quoted me a great price on some 7075. Finding a good local source is so nice...
