Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Unread 17-11-2012, 15:37
Re: Deploying code probleme
Originally Posted by Priyesh69 View Post
3) When deploying there a message that appears that say some vi are in conflits and need the be not run for the code to execute.
If that's the message I think it is, then it's not an error. It's just letting you know that there's already a program running on the robot, and if you continue to deploy the new program you'll replace the old program. Since that's exactly what you want to do, just tell it to continue.
