Go to Post I have long since stop trying to predict what the GDC will do. - FrankJ [more]
Unread 18-11-2012, 19:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Bearings in Sheet Metal
Most of my experience with sheet metal was in non-power transmission applications.
How do folks typically handle bearings when working in sheet metal? If you're working in .060" or something, do you build up around the bearing with additional sheet? What about thicker materials like .090" or even .120"?
--Madison--
...down at the Ozdust!
Unread 18-11-2012, 19:56
BJC's Avatar
BJC BJC is online now
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: Bearings in Sheet Metal
We use .09 for our gearbox sideplates. It works fine without extra material. We also make the holes .003-.005 smaller so the bearing fits tightly which prevents slop in the gears.
Our 2012 collector had bearings in .063 sheet which supported bevel gears. There were no problems with the bearings all year. Just make sure the bearing flange is flush with the metal - it's not like its going to rip out or anything. I wouldn't suggest going this thin for a gearbox though.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 18-11-2012, 20:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
With holes that much smaller there's no chance the bearings will fit. Did you leave out a zero?
Unread 18-11-2012, 20:33
Billfred's Avatar
Billfred Billfred is online now
For what it's worth, 2815 has had good luck with flanged bronze bushings for 1/2" shaft inside 1/16"-wall square tubing. In each case, the bushing only went through one side of the square tubing.
We ran them in our 2011 roller claw, and on our ball elevator and shooter axle this year. Any issues we had with any of these were unrelated to the bushings.
Unread 18-11-2012, 20:38
We've done the same.
Unread 18-11-2012, 20:44
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
If you use a flanged bearing, make sure it is well retained in the plate, and pinched axially on the shaft, you'll be fine even in something as thin as 063.
-John
Unread 18-11-2012, 20:52
BJC's Avatar
AKA: Bryan Culver
Nope, we just use a deburring tool or ream them out to make them a little bigger after they are waterjetted. I agree that they wouldn't fit unless you make the hole bigger.
Unread 18-11-2012, 21:02
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Exactly or even a little emery paper does the trick. On thicker materials we note which side is tapered by the water jet and a quick hit with a deburing knife usually results in a perfect fit.
Unread 18-11-2012, 21:05
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
It's funny that me and Akash just had a discussion about this the other night.
Last year 772 used 1/8" sheet (0.125") for everything and didn't thicken the area's where bearing went. Though it isn't needed we WILL be adding extra material around them this year. I am also probably going to make a "press" mechanism that will make the bearing become perfectly flush with the sheet. This year we went with cutting the bearing holes to the exact size, though with the "press" I would make it about 0.005" smaller. Along with press fitting the bearings I want to Bolt them in, the exact same way IFI bolts the bearings onto their wheels (plastic small washer to space washer, and washer on top of bearing, bolt and nut holding the washer down). The holes for the bolts would also be used to press the bearing into the metal.
You can see what I designed for a bearing press below. You need an Arbor press for it to work.
Name:	0.5 in bearing press.png
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 18-11-2012, 22:37
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
I have seen two cases where flanged FR8s (pressed in 1/8 plate) and flanged FR6s (pressed in 1/16 tubing) have had pretty great success. The most recent application was done with the FR6s for the 973 Hodgepodge Bot. So far, there hasn't been any records of the bearings or tubing failing.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 18-11-2012, 22:49
We added extra material in the drivetrain, but straight .09 gave us zero issues for the rest of the bot.
Unread 19-11-2012, 09:26
Brandon Holley's Avatar
On our intake, we needed to press in FR6 bearings in 2 places. The sides of the intake were made from 0.060" 6061 so we weren't totally sure how the press would hold up. We decided to play it safe and added 2 bearing plates that simply acted as a carrier for the bearing and would then bolt onto the intake.
The little plates actually ended up being a bit of a celebrity on the team and we ended up making them into little NUTRONs logos just for some extra flare (bottom right):
They worked out great. It was actually a cool feature too, because it allowed us to disassemble part of the intake from the opposite side where if a bearing were permanently pressed in place, we'd be unable to.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-11-2012, 09:38
-Brando
So your bearings were never pressed into the actual intake, they were only pressed onto these plates? I like that idea alot actually. Were they pressed in? Or bolted on to these plates? If they were pressed how much smaller, if any, were the holes made for the bearings?
Thanks, great idea btw.
2013-Present
2010-2013
Unread 19-11-2012, 09:58
Yeah the bearings were only pressed into the bearing plates. The bearing plates were then bolted to the intake.
For any part that we are making in-house we can reliably undersize the press fit to 0.0005" under and press with no issue. The most reliable way to get good press fits is to invest in the 2 reamers you would need to do 3/8" bore and 1/2" bore bearings (0.8745" and 1.1245"). This becomes a very repeatable process for your team, where you size bearing holes slightly under and ream to the final diameter. You will have much more consistent press fits this way. This will also help you where you may be using a process besides a CNC mill where the tolerances on the diameter may be a little bigger (ie: waterjet). Again, you'd undersize for the waterjet, and just finish with the reamer.
-Brando
Unread 19-11-2012, 10:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Another thing you can do if you want to have some fun, is press the bearings into polycarbonate sheet. We discovered that a Forstner drill bit will make a hole just the right size for this press fit.
This works well for smaller mechanism type gearboxes, and I think it has been used by AM to make drivetrain gearboxes too.
