Go to Post So we dont need a brain to run the minibot? - TheGuyz [more]
Unread 19-11-2012, 10:59
AdamHeard's Avatar
Lead Mentor
Re: Bearings in Sheet Metal
Originally Posted by sanddrag View Post
With holes that much smaller there's no chance the bearings will fit. Did you leave out a zero?
With Material that thin it works no problem. If you were pressing into material the same thickness as the bearing it'd be a different case.
Unread 19-11-2012, 11:22
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by squirrel View Post
Another thing you can do if you want to have some fun, is press the bearings into polycarbonate sheet. We discovered that a Forstner drill bit will make a hole just the right size for this press fit.
This works well for smaller mechanism type gearboxes, and I think it has been used by AM to make drivetrain gearboxes too.
We did this for our 2012 shooter. A total of 10 flanged bearings pressed into polycarbonate sheet. Worked great.
To put some numbers to the OP question:
Using a bearing like this one in 5052 aluminum (28KSI YS):
YS*(bearing OD*sheet thickness)=bearing load at material yield
28KSI*(.875*.0625)=1530lbf to reach yield in 5052 aluminum, assuming the bearing is seated properly and nothing is grossly misaligned. This is at least double the working load rating for most bearings of this size.
Unread 19-11-2012, 13:13
FRC #1836 (MilkenKnights)
Is undersizing .003-.005 better for thin sheet, or is reaming out to .001 undersized still better?
Unread 19-11-2012, 17:21
Michael Hill's Avatar
Originally Posted by IndySam View Post
Exactly or even a little emery paper does the trick. On thicker materials we note which side is tapered by the water jet and a quick hit with a deburing knife usually results in a perfect fit.
Water jets taper the material? Hmm...I didn't know that. You learn something new every day!
Unread 19-11-2012, 17:23
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Yes, and no.
Waterjetting naturally cut a taper in the material. However, if the waterjet machine has an angle compensating head, then the cut can be straight on one side of the cut.
Andy B.
Unread 19-11-2012, 20:49
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
It's called a 'kerf'. A skilled waterjet operator such as the gut I use for work can do a really good job minimizing the kerf's taper, even without a multi-axis head like Andy describes.
Unread 19-11-2012, 23:00
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Last summer, I was trying to cut some 1 module (metric) gears with a waterjet in about .4" thick material. Unfortunately, the kerf that yo mentioned prevented the gears from meshing properly.
Could you elaborate as to the methods used to help eliminate kerf? We tried cutting extra slow, but it didn't seem to help much. If you can cut propper bearing press fit holes with a waterjet using proper methods, to seems like cutting gears of at relatively large module would be trivial.
-Plutarch
Unread 19-11-2012, 23:11
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
You could just cut .125 plates and stack the gears. That would help quite a bit. Most places that we've used for work just compensate for the kerf via rotating head.
-RC
R.C.
MadTown Robotics Team 1323
Unread 19-11-2012, 23:39
AdamHeard's Avatar
Lead Mentor
You can also waterjet both gears, and run them opposite. We've done this in numerous places.
Unread 20-11-2012, 08:27
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
No idea how he reduces the kerf so effectively and I've never asked. I assume it's a trade secret of his so that we'll keep sending work to his shop.
He uses a pretty old 3-axis machine with no fancy features.
If I had to guess it's that he adjusts the pressure of the jet in conjunction with travel rate to reduce the kerf, but that's pure speculation.
