Go to Post I'm liking this. Programmers wont. But I will. :D - Rion Atkinson [more]
Unread 20-11-2012, 13:19
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
Lightbulb Writing custom Jaguar motor controller firmware
I was thinking about writing custom Jaguar motor controller firmware in order to use the limit switch inputs as encoder inputs. This would allow the Jaguar to handle more elements of control and also simplify wiring at least for me. But is there an SDK to do this?
Unread 20-11-2012, 22:01
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Writing custom Jaguar motor controller firmware
The Jaguar source code is available from TI (at least for now): http://www.ti.com/tool/rdk-bdc24-cd. More details in this thread.
I have to ask, though - Why isn't the built-in encoder input sufficient?
Also, be aware that last year it wasn't legal to use custom Jaguar firmware, per [R61]. I would be surprised if that changes this year.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 20-11-2012, 22:21
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
I suggest you study the RDK's specs on the limit switch GPIOs to verify that they can actually handle the frequency resolution that effective encoder input demands.
Also, on top of Steven's question, is there a reason you can't handle encoder processing through another interface? I can't see it would simplify your wiring either, or even why the Jaguar would need to juggle input from two encoders.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 20-11-2012, 23:26
FWIW, from LM3S2616 datasheet p348:
Each GPIO port is a separate hardware instantiation of the same physical block. The LM3S2616 microcontroller contains five ports and thus five of these physical GPIO blocks.
The Jag encoder inputs are on port C, and the limit switches are on port B.
Unread 21-11-2012, 00:06
AKA: Mark Omo
FRC #1703 (RATS)
I don't really want to write it because the functionality is not there mostly for the experience. Hopefully this year you will be allowed to customize your control system more this year.
Unread 21-11-2012, 01:54
s1900ahon s1900ahon is online now
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
What are your plans for handling the unpublished FIRST-specific CAN protocol extensions? In the past the encoders were not permitted without CAN.
If it is for fun and not FRC it is totally doable. Just watch the interrupt priorities to avoid starving the important stuff.
