Go to Post There is no charge. We just want to help. We are family… - emnasson303 [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Programming
Unread 19-11-2012, 17:16
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
[OCCRA]: OCCRA Cortex wiring for IFI SPike
Here's some information that can help you program the Cortex to operate the IFI spike. You have to make special PWM cable wiring changes to make this work properly.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 20-11-2012, 17:17
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
Re: [OCCRA]: OCCRA Cortex wiring for IFI SPike
For tools and materials to make these cables from scratch, there seems to be a general consenus that Hansen Hobbies (http://www.hansenhobbies.com/) makes the best tools and provides great materials. We have a $15 economy tool (http://www.hansenhobbies.com/product...ools/crimp_ec/) and one of the connector kits (http://www.hansenhobbies.com/product...rkits/ck_psck/) at $21, that we also use for FRC.
I think the alternative would be to solder two PWM wires together (sacrificing one connector) to achieve this wiring layout.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 20-11-2012, 18:09
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
When I only needed one side of the Spike, I just cut the red wire in the PWM cable and called it good. Actually, I think I removed it from the PWM terminal in such a way that I could re-assemble it if I ever wanted to use the cable again.
If I were to need both sides, I would likely pull out the red wire of the Cortex-side terminal and put it into a new shell, that's probably the easiest.
Kettering Motorsports
Unread 22-11-2012, 22:49
kenavt's Avatar
AKA: Colin S
That's precisely what we did (for a spike we never used). I recommend this thread be stickied, because it took me a long while to find the article post referenced by Marc, and I think this page will be relevant for a while longer.
Unread 22-11-2012, 23:18
marccenter's Avatar
Andrew,
An important benefit of keeping the red wire in the connector and perhaps cutting it off a few inches from the connector is that it increases the friction forces which helps the connector stay in position in a controller such as the Cortex. When I built Cortex compatible cables I actually built a 2 row by 3 column Molex connector in the Cortex (3 pins) configuring the IO to use 2 digital adjacent outputs. I then used the two adjacent (white) signals to go to the Spike PWM cable where it became red for one and white for the other. I only used one wire for the black on both sides. Because the connector came out somewhat easily, I found myself adding a red wire jumper on the Cortex side so I now had 5 pins filled in the 2 by 3 Molex connector.
Oh yes, both sides of the Cortex to spike pwm cable were made with male pins so that no adapter was necessary to be used in the Cortex like the typical use of a pwm extension cable.
BTW, thanks for your posting Colin S on the PWM cables from Hansen Hobbies ... very helpful.
Marc Center
Unread 23-11-2012, 10:38
apalrd's Avatar
More Torque!
VRC #3333
We solve any friction-fit PWM cable issues with RTV.
Unread 23-11-2012, 21:53
marccenter's Avatar
Andrew,
Do you have a picture of how you used the RTV to help you? Blue RTV? I might have guessed the use of a hot glue gun but not RTV.
Marc Center
Unread 24-11-2012, 00:49
apalrd's Avatar
More Torque!
VRC #3333
Clear, usually.
We usually take a very large blob and glue all of the PWM cables into their destination. We also try to get as much contact area as possible by forcing it into the cracks between the two connectors.
For inline connections, we usually wrap a small zip tie through the cables, instead of using RTV.
