Re: PVC Rollers?
Like, anywhere from 1/4" to 1/2" deep. I haven't seen PVC with a wall that thick, unless they were using a bunch of small segments of PVC connected by some sort of fittings to simulate grooves. |
Re: PVC Rollers?
I've seen more ABS rollers than PVC. ABS plastic is more appropriate for this type of application (less shatter-y, rougher surface finish), and generally comes in thicker walls, which can be machined. However, it can be much easier to add grooves onto the surface of a roller than cut them into it. The solution can be as simple as a couple of donuts cut from plate stock and epoxied to the surface of the roller.
Re: PVC Rollers?
On 330 we just cut thin sections of PVC pipe and then make a slit in the resulting ring. The sections are then glued to the main roller on either side of the spot where you want the belt to be using PVC cement. Simple, effective, and cheap
Re: PVC Rollers?
This is exactly what we did as well, but with Polycarb tubing. It requires no machining time other than a bandsaw and provides the same function. |
Re: PVC Rollers?
Do you do anything to fill the gap that spreading the ring makes? We did this method one year, and it worked, but looks left more than a bit to be desired.
Re: PVC Rollers?
Our end caps were just UHMW disks with a hex in them. |
#7
Re: PVC Rollers?
We prototype using PVC with wood plugs in the ends and 1/4 20 bolts sticking out long enough to put electric hand-drills on for proto-power...
On production, we use hollow aluminum tube with Nylon plugs in the ends and we press aluminum shafts in, spinning on lubricant-infused bushings.. I think going forward we'll skip the bushings and use sealed-bearings if weight/cost isn't an issue. As for keeping Polycords in-place... we abide by the 148 Robowranglers credo... "IF gum-rubber isn't the answer, THEN you're asking the wrong question..." LOL SERIOUSLY, the black gum-rubber works _great_ creating channels and looks _awesome_!! < some scrolling pictures www.broncbotz.com > You need to apply at least TWO layers and super-glue each layer... From McMaster: 4568T18 Architectural Anodized Aluminum (alloy 6063), Tube, .065" Wall Thk, 1-1/2" Od, 1.370" Id, 6' L 93625K58 Natural Gum Foam, Adhesive-backed, 1/8" Thick, 1-1/2" Width, 50' L 8541K56 3 Ft. Wear-resistant Black Nylon Rod, 1-3/8" Diameter Last edited by Michael Blake : 25-11-2012 at 10:39. |
#8
Re: PVC Rollers?
We machined them from 2" delrin round stock. Very simple to do.
#9
Re: PVC Rollers?
We did the same.. expect out of 1.25 billet 6061.
