Go to Post I haven't been negative about any FIRST game yet, but scaling and cleaning fish in 2009 that were used in 2008 is going to stink. Literally. :P - Billfred [more]
Unread 25-11-2012, 01:19
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
PVC Rollers?
I've asked this before on the forum last build season, and absolutely no one replied
So I've come to ask it again.
Can anyone link me or show me where to get PVC rollers for conveyor systems utilizing polycord?
Last year we were so misguided we ended up buying those foam rollers (the ones used for exercise).
Thanks in advance.
Unread 25-11-2012, 01:26
Re: PVC Rollers?
Thanks in advance.
I'm not sure what foam rollers you speak of, but a lot of teams just purchase PVC from Home Depot or a similar store for their rollers. It is just pvc tubing that teams can machine grooves into or put rings around the PVC pipe to capture the polycord in place, but it is nothing special.
Other teams use other materials for their tubing: aluminum, acetal, polycarbonate, etc.
Unread 25-11-2012, 01:28
ksafin's Avatar
AKA: Kirill Safin
Re: PVC Rollers?
I don't have a picture on me, but for some of the bots I saw, the grooves were HUGE and DEEP.
Like, anywhere from 1/4" to 1/2" deep. I haven't seen PVC with a wall that thick, unless they were using a bunch of small segments of PVC connected by some sort of fittings to simulate grooves.
Unread 25-11-2012, 01:42
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: PVC Rollers?
I've seen more ABS rollers than PVC. ABS plastic is more appropriate for this type of application (less shatter-y, rougher surface finish), and generally comes in thicker walls, which can be machined. However, it can be much easier to add grooves onto the surface of a roller than cut them into it. The solution can be as simple as a couple of donuts cut from plate stock and epoxied to the surface of the roller.
Unread 25-11-2012, 02:06
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: PVC Rollers?
Thanks in advance.
McMaster catalog page
There are a variety of sizes and material options. Take a look around McMaster or Grainger searching for 'Conveyor rollers' and you'll turn up some more.
For what it's worth, 95 used some rollers from McMaster last season and they worked out alright. We ran actual conveyor belting around them. Our early tests using polycord was suggesting it was going to be more trouble keeping them on track then it was worth in weight savings.
Unread 25-11-2012, 02:08
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: PVC Rollers?
On 330 we just cut thin sections of PVC pipe and then make a slit in the resulting ring. The sections are then glued to the main roller on either side of the spot where you want the belt to be using PVC cement. Simple, effective, and cheap
Christopher H Husmann, PE
"Who is John Galt?"
Unread 25-11-2012, 02:10
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach - FRC Under Development
FRC #6370 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
Re: PVC Rollers?
We prototype using PVC with wood plugs in the ends and 1/4 20 bolts sticking out long enough to put electric hand-drills on for proto-power...
On production, we use hollow aluminum tube with Nylon plugs in the ends and we press aluminum shafts in, spinning on lubricant-infused bushings.. I think going forward we'll skip the bushings and use sealed-bearings if weight/cost isn't an issue.
As for keeping Polycords in-place... we abide by the 148 Robowranglers credo... "IF gum-rubber isn't the answer, THEN you're asking the wrong question..."
LOL
SERIOUSLY, the black gum-rubber works _great_ creating channels and looks _awesome_!! < some scrolling pictures www.broncbotz.com > You need to apply at least TWO layers and super-glue each layer...
From McMaster:
4568T18 Architectural Anodized Aluminum (alloy 6063), Tube, .065" Wall Thk, 1-1/2" Od, 1.370" Id, 6' L
93625K58 Natural Gum Foam, Adhesive-backed, 1/8" Thick, 1-1/2" Width, 50' L
8541K56 3 Ft. Wear-resistant Black Nylon Rod, 1-3/8" Diameter
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- Head Coach / Founder - FRC 6370 Texas Titans < FRC and VEX teams under development - VRC 15842a >
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
Unread 25-11-2012, 03:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: PVC Rollers?
We machined them from 2" delrin round stock. Very simple to do.
Unread 25-11-2012, 03:32
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: PVC Rollers?
We did the same.. expect out of 1.25 billet 6061.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 25-11-2012, 03:38
Re: PVC Rollers?
This is exactly what we did as well, but with Polycarb tubing. It requires no machining time other than a bandsaw and provides the same function.
Unread 25-11-2012, 03:43
Joe G.'s Avatar
AKA: Josepher
Re: PVC Rollers?
Do you do anything to fill the gap that spreading the ring makes? We did this method one year, and it worked, but looks left more than a bit to be desired.
Unread 25-11-2012, 03:49
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: PVC Rollers?
Thanks in advance.
'Tis just standard PVC and end caps (obviously drilled into them for the axle) purchased at the local home depot. The rings around the PVC that keep the polycord in place are just strips of another pipe of a slightly wider diameter (It may even be a end cap that we chopped up and slid on, I don't remember exactly).
Unread 25-11-2012, 04:27
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Re: PVC Rollers?
It's great to mention and bring up in this topic regarding what materials you should use for your rollers. Everyone knows a combination of ABS, Delrin, Aluminum, PVC, ect. Another one to throw in there is wood and 1114 used it effectively this year on their intake. It's just a great thing to remember that some of the most "effective" components of a system may just be in a scrap pile in your high schools woodshop.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 25-11-2012, 10:07
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: PVC Rollers?
If you're specifically interested to machine a roller from PVC then you might try schedule 80. It's thicker than Schedule 40 and usually dark grey.
McMaster sells it.
We have used it in the past with polycord. It worked well.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 25-11-2012, 10:43
Re: PVC Rollers?
I ADDED to my above post the materials we use purchased from McMaster.com
Hope this is helpful...
