Specs on sensor say:
Off-State leakage current: less than 50 uA @30V On-State Saturation Voltage: less than 1V @10 mA, less than 1.5V @ 100mA When you played around with the sensor, do you recall what the actual voltage produced was that goes into the digital input on the robot controller? e.g. If I supplied 12 V power to the sensor... For ON position, is voltage at output 5V or 0V ? For OFF position, is voltage at output 5V or 0V ? Do you know if these Banner Sensors, can detect a analog signal, something that ranges between 0 and 5 V? Anyone try it out? FYI. |
| Q&A Discuss: Optical sensors with EduBot | CD47-Bot | Extra Discussion | 2 | 01-03-2003 18:37 |
| Q&A Discuss: optical sensors | CD47-Bot | Extra Discussion | 0 | 15-02-2003 22:58 |
| optical sensors acting strangely | rosebud | Electrical | 10 | 03-02-2003 00:29 |
| Find any optical sensor in catalogs? | GreenDice | Programming | 1 | 13-01-2003 18:05 |
| OPTICAL SENSORS??????????????????? | NM_programming | Technical Discussion | 2 | 13-01-2002 17:41 |
