Go to Post We owe a lot to Bob (Hammond), he is a true gentleman. - Covey41 [more]
Unread 25-11-2012, 10:38
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Wind River setup won't start on Windows XP 64bit
Hey,
I have the two Wind River cds. When I open up setup.exe on the first CD, the installation wizard pops up, but when I click "Next" nothing happens - the window stays exactly the same. What can cause this problem?
Thank you,
Itamar
Unread 25-11-2012, 21:04
mythbusterma mythbusterma is offline
mythbusterma is an unknown quantity at this point
Re: Wind River setup won't start on Windows XP 64bit
The newest edition of WindRiver may not support your OS, I'd recommend trying to get a different computer to run it.
Unread 06-01-2013, 19:07
mprasolov's Avatar
mprasolov mprasolov is offline
Jack of all trades
AKA: Misha Prasolov
FRC #2823 (The Automatons)
Team Role: Student
mprasolov is an unknown quantity at this point
Try running as administrator, Win XP *should* be compatible with WRWB!
Unread 08-01-2013, 00:53
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
We installed on 4 WinXP 32-bit machines already - it is indeed functional on them. These were not 64-bit but thought I'd throw out our experience.
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 08-01-2013, 01:21
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Where did you find Windows XP 64-bit? There are two distinct versions you could be referring to, and they're both rare and very outdated.1
The version actually called Windows XP 64-bit edition is actually for the IA-64 (Itanium) architecture, not x86-64. If you were running an Itanium processor, you'd know it, and wouldn't be altogether concerned that Wind River didn't run.2
Instead, you're probably dealing with Windows XP x64 edition, which is actually based on Windows Server 2003. The installer might silently choke if it has a hardcoded version list that supports Windows NT 5.1 (32-bit XP), but not 5.2 (Server 2003 and its variants).
I'm not sure if it supports compatibility modes—but try them if possible. If it's just the setup executable that doesn't work, it might be possible to unpack it as an archive (use 7-Zip or similar), and run the .msi file directly. You could also do various things to install it on another system and transfer the completed installation (maybe after running a repair/restore installation from Add/Remove Programs to fix registry entries).
You may be better off just finding another OS, or running a virtual machine (if that even works properly—I haven't tried it).
1 While I sometimes get a little annoyed when software vendors don't adequately support versions of Windows that have been in public beta—or even commercial release—for months, a decade-old OS probably doesn't merit much development work any longer.
2 Also, the thought of someone writing a compiler for Windows on IA-64 to target VXWorks on PowerPC is just about the most perverse thing ever. (And that's saying a lot. There was some pretty perverse—but rather impressive—optimizing compiler development going on for Itanium.)
