Go to Post theres no such thing as the best robot...cuz every robot is the best :D - [more]
Unread 29-03-2012, 18:02
nazgul42 nazgul42 is offline
FTC #4115
nazgul42 is an unknown quantity at this point
RobotC communication over Wifi
I am the programmer for a team in the FTC competition. I am trying to use the Samantha module to download and debug programs. I am able to find and connect to the NXT brick through the Communication Link Setup dialog. However, when I try to download a program to the brick, the following errors appear.
WiFi link to NXT brick has failed. Brick may have powered off or out of range. Close this window. Ensure brick is powered on. Wait 5-15 seconds for NXT for WiFi re-initialization and situation may auto-recover.
After that, another dialog box appears.
Failed to completely download all system configuration parameters to robot controller. Ensure that latest firmware is loaded onto controller and all cables are tightly connected.
I have just updated the versions of the RobotC, NXT Driver, Samantha FCS, and Samantha drivers. I am able to connect to the brick over the Samantha Field Control System, and that works as expected.
What am I missing here?
Unread 25-11-2012, 15:19
David Fort David Fort is offline
FRC #1001
David Fort is on a distinguished road
Re: RobotC communication over Wifi
Hi, Team 6335 is having this problem now too.
Did you ever figure out what the fix is?
Thanks,
David Fort
FTC/FRC 1001
Unread 25-11-2012, 15:35
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
We use BlueTooth for our communications, but how are you doing it?
Do you
1) Have SamoStat installed on the NXT
2) Have the latest firmware installed on your Samantha Module
3) Have the Samantha Module & PC both connected to the same network?
Also, when we tried to use Samantha to test last year over Wifi using RobotC, it didn't work period (Team 5257)
RobotC has been known to have problems deploying over WiFi.
Unread 26-11-2012, 23:01
zoemcrae zoemcrae is offline
FRC #0111
zoemcrae is an unknown quantity at this point
RobotC V3.55beta definitely can download over wifi. However you need to enable this on the preferences menu (VIEW/PREFERENCES/ENABLE SEARCHING OVER WIFI). Since this option isn't actually displayed on the COMMUNICATION LINK SETUP page it isn't that ovbious it even exists!
Unread 26-11-2012, 23:57
FRC #0111
In addition, when first connecting RobotC to your robot you'll have to press the red Samantha button to pair. This is true even though the robot has previously been paired with the FCS on the same PC you're running RobotC.
The Samantha will be continuously cycling through the three LED's RED/WHITE/BLUE/WHITE/RED when it needs to be paired.
Unread 07-12-2012, 06:46
FRC #1001
Thanks for the replies.
It isn't our team having trouble, so I can't confirm all the details (e.g. version of Samantha firmware).
The attempt is to communicate to Samantha through E1200 wifi router.
They are getting the SAME error as the team that opened this thread last spring.
We will see them this weekend at a FTC Scrimmage near Cleveland, and I'll pass along the suggestions so far. Any others?
Thanks much.
