Go to Post FIRST isnt about getting what you deserve, FIRST is about other people seeing potential in us - and giving us an opportunity that we could never have earned on our own - KenWittlief [more]
Unread 25-11-2012, 17:40
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
Re: 2583 Off-Season Drivetrain Help
It looks like you are going with a live axle system to transfer the power, however i do not see bearing in the aluminum extrusion. If you do not put bearings the abrasion of the shaft rubbing on the profile of the hole will damage both the metal and the shaft.
Also in a live axle system you will need hubs on/in the wheels rather then the bearings (i think) you have currently.
Also you may want to add another corner gusset on top.
Excellent first CAD, i look forward to seeing great things in the future!
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 25-11-2012, 20:37
ferrari77 ferrari77 is offline
FRC #2583
ferrari77 is on a distinguished road
After looking more closely I see the problem in my CAD
I have never dealt with hubs separate from the pulley because our team has always chained our drivetrains with the sprocket directly attached to the wheel
The pulley is attached to the axle with a set screw so they will spin together
How would I go about connecting this wheel to the axle so they spin together?
I looked at Andymark's website and found these hubs
http://www.andymark.com/Hubs-s/215.htm
Most of them used keyed axles and we do not have the resources to machine a keyed axle, can you buy those?
Unread 25-11-2012, 20:51
FRC #1836 (MilkenKnights)
Yes, you can get keyed axle from many sources. Mcmaster is a fine source to get keyed axle if you don't need much bulk. Because you said that you have a lathe, I highly recommend hex axle though because it makes assembly easier. Andymark sells both hex bearings and hex hubs. West Coast Products sells colson hex hubs and 1/2 undersized 7075 hex.
Unread 25-11-2012, 21:39
FRC #2583
I made the pulleys have a hex bore and attached a hex bore hub to the wheel so they will spin with the axle
Now how do I deal with the axle going through the frame right now with no bearing?
I thought about using a bearing hub and mounting it to the side of the aluminum channel but the axle is now a hex axle and I cannot find bearings that fit hex axles
Any thoughts on how I fix this?
Unread 25-11-2012, 21:43
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Honestly there have been quite a few links to andymark already. They sell hex bearings. Go and look.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 26-11-2012, 01:20
FRC #2583
I have included a link for the .step file of the chassis now
I included a lot of the changes you guys suggested
I still have to include the rest of the electronics and figure out a tensioning design but that will come later
The red things on the wheels are the colson live axle hubs
http://wcproducts.net/wcp-00053/
The blue things on the aluminum channel (seen from the bottom of the robot) are AndyMark hex bearings with flanges
http://www.andymark.com/product-p/am-0279.htm
The hole in the aluminum channel is slightly smaller than the OD of the bearing so they will be pressed in and there is a small flange on the bearing which will keep it from going too far.
Also the axle is now hex and the pulley has a hex bore so they are connected
Do you guys have any more comments or suggestions?
Your help has been very useful so far, im learning a lot
Download Link:
http://www.2shared.com/file/kdrucknG/chassis1.html
Unread 26-11-2012, 21:43
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
I think this is much better.
However a few things I notice:
  • Is there a reason you have the large plate on top of the frame rather than below it? If there isn't a reason, you could probably move it below and protect the electronics a little easier.
  • I would recommend that you try to support the gear box output shaft on the end.
  • I would also only make the shafts 1/2" hex at the wheel. By turning it down to regular 1/2" you save yourself the need to purchase a broach. Additionally you can save money by purchasing regular 1/2" bearings ($7 vs $9.50) rather than hex bearings.
Again, this design is much better now, good job.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 26-11-2012, 21:53
FRC #2583
  • I would also only make the shafts 1/2" hex at the wheel. By turning it down to regular 1/2" you save yourself the need to by a broach. Additionally you can save money by purchasing regular 1/2" bearings ($7 vs $9.50) rather than hex bearings.
Would it make it the structure stronger if I put the board below or is just for the sake of protection? I could definitely put it below if its better
I thought about doing this for the axles but we only have a lathe and I dont think we have any tools to turn a round axle to a hex axle
Mcmaster sells hex axles which are long enough but the hole axle is hex
Is there a way for us to make the part of the axle hex without buying anything?
Unread 26-11-2012, 22:04
Garret's Avatar
AKA: Garret Smalley
You can buy 1/2" hex shaft and turn it down to just regular round 1/2" shaft with a lathe its a pretty standard operation. You would then just use either set screws or cotter pins for the sprockets.
Putting the plate on the bottom of the frame is what is normally done. In my opinion it looks cleaner, helps lower the Center of Gravity, and allows you to attach a superstructure easier.
7 Years of FRC
Unread 26-11-2012, 22:05
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
A. WCP is selling hex bearings for $7.5.
B. You can turn hex into round shaft with a standard lathe that has a 3 jaw check and just HSS tool. Also the hex pushing up against the bearing would help retain the shaft in place
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 26-11-2012, 23:23
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
I'm not really a drivetrain expert, but maybe you could save some weight by cutting a lightening pattern into the electronics board.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 26-11-2012, 23:36
FRC #2583
I've been waiting to do this because our team does not know if we will have access to a laser cutter
If we do I can do a cool looking lightening pattern with diamonds and triangles
If not I will do what we have done in the past with just rows or circles
Unread 26-11-2012, 23:45
I also recommend a garolite bellypan if you aren't able to get a bellypan lasered.
Unread 16-01-2013, 11:39
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
I would use chain instead of pulley belts, they don't slip as much and are more reliable.
Unread 16-01-2013, 13:00
Gregor's Avatar
Really? How do you know? What do you mean by "don't slip as much," and why are they "more reliable?"
There is no defined better in terms of chains or belts.
<Since 2011
