Go to Post They truncated our conference title. We are not showing the movie "Finding NEMO" - RoboMom [more]
Unread 11-11-2012, 10:57
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Do I need to delete the Command objects?
Ahoy ahoy!
This year our team decided to work with C++. I was reading this excellent pdf when a thought occoured to me: do I need to clear the memory of all the Command instances I create? If so, will it work to simply write "delete this;" at the "end" method?
Or maybe creating instances during runtime is not right at all, and all Commands should be created at the beginning and re-used while the robot runs?
Thank you,
Itamar
Unread 25-11-2012, 21:08
mythbusterma mythbusterma is offline
mythbusterma is an unknown quantity at this point
Re: Do I need to delete the Command objects?
It seems that by the way they implement commands, the commands automatically lose scope after they finish executing, and hence are deleted.
