Go to Post If you don't manage weight from the beginning, weight will manage you at the end. - charrisTTI [more]
Unread 25-11-2012, 21:39
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Rivet tools--what's out there today?
Originally Posted by MICHAELABICK View Post
RC when do you use the wide domed rivets. Do you also use 1/8 or do you use 3/16 exclusively?
Micheal,
We do not actually use wide domed rivets. For some reason we prefer the smaller guys. No real reasoning, maybe price? or the ability to get all of the same kind? I honestly couldn't tell you what our thought process was here.
But we use 3/16" on our entire bot, its easy to go:
We have a #10 hole, we can:
-Bolt
-Rivet
-Ziptie!
Makes life easy for us as designing in another set of holes would be a pain, we stole from 973 the #10 bolt pattern idea. So we put #10 holes every .5" inches. We also make a lot of changes on our bot, so the bolt pattern is pretty sweet and versatile.
The 1/8" rivets aren't used nearly as much, the reason we actually have them is we spend a lot of time letting new kids explore ideas and making prototypes. We buy 1/32" - 1/16" polycarbonate (3-4 sheets) and a ton of 1/8" rivets, this allows us to make prototypes cheaply and easily. The 1/8" rivets are really easy to use with a manual riveter. 1/8" rivets have a purpose, but they are not really used on the bot.
-RC
R.C.
MadTown Robotics Team 1323
Unread 25-11-2012, 22:01
FRC #1836 (MilkenKnights)
Originally Posted by R.C. View Post
Micheal,
-Bolt
-Rivet
-Ziptie!
-RC
That was my mistake on the wide domed rivets. When I saw the link for the "Domed for Wide Thickness Range" rivets I somehow thought that they were wide domed. Thanks for the information about the 1/8" rivets. We have been planning to steal the same 973 bolt pattern, and it is good to know that the 3/16" rivets will handle all of our needs.
