Go to Post Battle Bots and other robot fighting competitions is to First Like McDonalds to Hamburgers They get the idea, and have the taste, but they are bad for you in the long run. - Conor Ryan [more]
  #31   Spotlight this post!
Unread 25-11-2012, 22:07
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: Be afraid... Be VERY Afraid
Well, it looks like by changing which wheel touches the ground, you can also change the clearance under the chassis. The hard stop looks like the vertical mounting touching the cim (The piece of metal which looks like a bell curve in the back). It looks like you could add 3, 4, maybe even 5 inches in your floor to chassis clearance.
(The big wheel looks like it can rotate clockwise all the way to where the little wheel starts)
Still want a top/bottom view
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
  #32   Spotlight this post!
Unread 25-11-2012, 22:08
DanielDTech's Avatar
DanielDTech DanielDTech is offline
Captain
FRC #0714 (Panthera)
DanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of light
Originally Posted by CalTran View Post
I don't think it flips 180, as that CIM will have a hard time going through the mounting material. I think it's just aesthetically pleasing.
Indeed, it is aesthetically pleasing and it does not flip. But don't totally throw away the pivoting idea
  #33   Spotlight this post!
Unread 25-11-2012, 22:09
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Well, it's obvious you're itching to tell us more...so out with it!
  #34   Spotlight this post!
Unread 25-11-2012, 22:12
Captain
Originally Posted by rcmolloy View Post
I hate to do this but here's a much larger image for everyone's viewing pleasure.
Also, I'm probably 100% wrong but it could possibly be that you have an 8WD narrowed down to a single module.
You are 100% wrong Thanks for posting the larger image.
  #35   Spotlight this post!
Unread 25-11-2012, 22:13
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Is this thing self-pivoting? Or do you just not have the pivoting setup in this model?
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #36   Spotlight this post!
Unread 25-11-2012, 22:15
Captain
I don't have the pivoting setup on here... This is about 30% of the actual mechanism.
  #37   Spotlight this post!
Unread 25-11-2012, 22:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Automatic load balancing/switching between pushing force and higher speed? A CVT in there somewhere? Most of the device (as we know it so far) is shown in the render. I don't see any mystery really. I must be missing something here.
  #38   Spotlight this post!
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Well that doesn't do us much justice xD
  #39   Spotlight this post!
Unread 25-11-2012, 22:19
Captain
Originally Posted by sanddrag View Post
Automatic load balancing/switching between pushing force and higher speed? A CVT in there somewhere? Most of the device is shown in the render. I don't see any mystery really. I must be missing something here.
You're missing nearly everything . Like I said, this is about 30% of the mechanism. It's not at all what you guys think it is.
  #40   Spotlight this post!
Unread 25-11-2012, 22:20
EricH EricH is online now
This is certainly revolutionary, keep in mind that there is a HUGE concept that you're not seeing here.
Allow me to point out that if we can't see the concept (a third of it is missing), there is no way that we can tell if it's revolutionary or not. It may be that several teams have already done something--in that case it's NOT revolutionary unless there is something completely new.
What it is is it's a pivoting drivetrain section. If there is something else that is part of the drivetrain, that makes it different from any other pivoting drivetrain like an octocanum or the pivot-shifters of yesteryear, then it's either not put in or very well camouflaged.
Unless those two bolts at the near visibility side indicate modularity, that is, the ability to swap it out for another module in drivetrain, I think you need to raise the stakes significantly--say, pay $100 and hire whoever guesses correctly to decipher the game hint for you. (Incidentally, the modularity concept could run you into some trouble if you don't do it right--all modules go through inspection at the same time.)
  #41   Spotlight this post!
Unread 25-11-2012, 22:22
Captain
If anyone can correctly guess what this is, I solemnly swear that I will send you $15.00 on paypal before kickoff.
Here's a top view for ya
  #42   Spotlight this post!
Unread 25-11-2012, 22:26
Captain
What I said was two thirds of it is missing. No modularity here. And I purposely took out the distinguishing part of the mechanism so that it wouldn't be completely obvious. There is definitely something completely new here, no doubt about it
  #43   Spotlight this post!
Unread 25-11-2012, 22:29
Raise the stakes, then. $1000 and payment to guess the game from the game hint. You're NOT going to get anybody guessing correctly if you only give us 1/3 of the mechanism. See also "game hint".
  #44   Spotlight this post!
  #45   Spotlight this post!
Unread 25-11-2012, 22:32
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
While driving one way it uses one of the wheels, when it reverses the belt/wheel setup pivots around to go onto the other wheel with a different torque/speed.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
