Go to Post What does code sound like going though a complier? - Hiteak [more]
  #46   Spotlight this post!
Unread 25-11-2012, 22:32
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Be afraid... Be VERY Afraid
I'm going to guess that part of it is weight reduction. It looks like it could be made very light.
It also looks very compact.
One thing that makes it unique is that this allows for both independent wheel drive AND two speeds/torques w/o the extreme cost/weight/space penalty that would result from one using 4 AM2/Supershifters. Even compared to using 4 dewalts (not as tall but much longer in the wheel axis), it looks very space efficient.
It also looks like it is meant to be mounted through a hole in a sheet metal base/pan. Perhaps even a sheet of plywood or other flat material. Maybe this is to simplify frame design? (Just a pan with 4 wheel holes?)
Or maybe it could be mounted in a lazy susan (the missing part mentioned) and used as a crab module? There have been 2 speed crab drives before (I know 1625's done it) but they all used non-independent drive systems (1625 used two drive shafts with miter gears to drive 6 wheels, 3 per shaft).
Another aspect I see is that the Cim is off center. Perhaps some sort of a counterweight?
Last, Perhaps another benefit of the design is that if you tossed a tread on the wheel (if it had such a tread), you'd already have a spare wheel you could toss in. Then again, this "automated spare tire" effect is also
  #47   Spotlight this post!
Unread 25-11-2012, 22:34
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
"Simpsons did it."
Err... I mean... is it a dual wheel rocker where each wheel is a different speed with an automatic shifter mechanism?
  #48   Spotlight this post!
Unread 25-11-2012, 22:35
DanielDTech's Avatar
DanielDTech DanielDTech is offline
Captain
FRC #0714 (Panthera)
DanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of light
Originally Posted by Akash Rastogi View Post
If i show the entire mechanism, there will be no guessing involved here... The point is to try to guess what that distinguishing component is. I don't believe anybody could do it, because of how out of the box it is. If it were easy, I wouldn't put $15 on it
  #49   Spotlight this post!
Unread 25-11-2012, 22:36
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Originally Posted by DanielDTech View Post
out of the box
Its from Andymark.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #50   Spotlight this post!
Unread 25-11-2012, 22:37
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
In this day and age, if you have something "truly revolutionary!!!!", you should be busy writing a patent for it and not bragging about it on a forum
  #51   Spotlight this post!
Andrew Lawrence
Posts: n/a
Is the distinguishing component clearly visible on this photo (by clearly visible, I mean it is something we can see a decent portion of, it doesn't need to be shining in gold and covered in red paint)?
  #52   Spotlight this post!
Unread 25-11-2012, 22:39
Captain
The distinguishing component is in fact completely removed from the assembly.
  #53   Spotlight this post!
Unread 25-11-2012, 22:40
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Suddenly, I'm missing the point of this thread.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
  #54   Spotlight this post!
E_puello E_puello is offline
FRC #3161 (Tronic Titans)
E_puello is a jewel in the roughE_puello is a jewel in the roughE_puello is a jewel in the roughE_puello is a jewel in the rough
Is it a gearless 2 speed swerve module?
  #55   Spotlight this post!
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
It goes on the outside of the robot haha
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
  #56   Spotlight this post!
dodar's Avatar
Are you seriously that slow? You want us to guess on what makes this different, and yet you took out what makes it different...
  #57   Spotlight this post!
Unread 25-11-2012, 22:41
Captain
Originally Posted by dodar View Post
Its from Andymark.
Nope
  #58   Spotlight this post!
Unread 25-11-2012, 22:43
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach
VRC #15842 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
Well it looks like it definitely flips in the direction of the larger wheel with the larger wheel traveling under to other side raising the small wheel way up in the air and flips the CIM completely to the other side...
IF NOT... just shoot me... LOL
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
  #59   Spotlight this post!
Unread 25-11-2012, 22:44
Captain
Very nice guesses! The unit is indeed very compact and light; it needs to be, since there will be more than one on the robot. But the big secret here is actually much simpler than any of these great educated guesses.
  #60   Spotlight this post!
Unread 25-11-2012, 22:46
Captain
Originally Posted by Michael Blake View Post
Well is looks like it definitely flips in the direction of the larger wheel with the larger wheel traveling under to other side raising the small wheel way up in the air and flips the CIM completely to the other side...
It definitely doesn't pivot that much xD but I will not shoot you sir
