Go to Post A good way to minimize the possibility of breaking things is to minimize the number of things that can break. - s_forbes [more]
  #76   Spotlight this post!
Unread 25-11-2012, 23:24
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Be afraid... Be VERY Afraid
"Hey guys, check out this super awesome thing I made, which is exactly what multiple teams made 8-9 years ago, with some revolutionary component missing. You have no possible way of guessing what is missing because I've given you absolutely no details, but I will string this thread along for the next month because it's fun to have lots of people wondering what my (not so) revolutionary design will be"
Does that about cover it?
2001-2004: Team 100
2006-Present: Team 254
  #77   Spotlight this post!
Unread 25-11-2012, 23:28
DanielDTech's Avatar
DanielDTech DanielDTech is offline
Captain
FRC #0714 (Panthera)
DanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of lightDanielDTech is a glorious beacon of light
Originally Posted by Harkirat Batoo View Post
Judging from the ratios I see, the wheels seem like they would be spinning at approximately the same speed, also the way the assembly is mounted suggests that it pivots, and the shape of the cut out of the mount suggests the smaller wheel can be raised significantly. In my opinion, this seems like a mechanism to either raise the chassis to over come an obstacle or a mechanism that allows a team to switch the configuration of their drive terrain during a mach, for example switching from a 4 wheel to an 8 wheel or 6 wheel to an 8 wheel or any other combination.
No. Much more simpler and out of the box as that.
  #78   Spotlight this post!
Unread 25-11-2012, 23:31
Originally Posted by Cory View Post
"Hey guys, check out this super awesome thing I made..."
http://www.youtube.com/watch?feature...LzPqo1qfU#t=4s
  #79   Spotlight this post!
Unread 25-11-2012, 23:32
Captain
Hey guys, check out this extremely super awesome thing I made, which is not not exactly what multiple teams made 8-9 years ago, with some revolutionary and simple component missing. You have little way of guessing what is missing because I've given you very little details, but I will string this thread along for the next month because it's fun to have lots of people wondering what my extremely revolutionary drive mechanism will be.
I've made some edits, please review.
  #80   Spotlight this post!
Unread 25-11-2012, 23:34
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Originally Posted by JVN View Post
GAME HINT!
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
  #81   Spotlight this post!
Unread 25-11-2012, 23:37
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
A couple thoughts on the design of what is revealed..
1. I don't think that putting this in a swerve module would be very smart. It is apparent that the small wheel can't be pivoted down until it reaches the center of the assembly. If this were on a pod that could turn the wheel touching the ground would literally be dragged sideways because the pod wouldn't pivot around the center of the wheel as is apparent in the top view. I'm ruling out swerve as this seems like it would probably be pretty suckish in that application. (Unless it only pivots when the big wheel is in the perfect position, again not that great a design.)
2. You only have mounting holes for this assembly on the wheel side which is presumably the outboard side of the chassis. This assembly either nests into another part of the chassis or else I would say that is also a design failure as the entire module would be in cantilever.
3. It appears that the axle that you are using to pivot on is live as it is modeled the same way as the wheel axles. If this is the case you could be doing something interesting where your drive motor also pivots the module, a second motor that pivots the module assists in powering the wheels (never mind), or if these are on a drivetrain with two to a side then the front and back can be chained together via this shaft. There is also very little holding those two halves together if all of those shafts are live. All I see is two standoffs by the motor. Based on the pictures I would try to get a standoff towards the big wheel side of the pivoting assembly.
4. If four of these are going on the Outer corners of a chassis I would be concerned about being able to turn. Your basically running a four wheel drive which picking up some wheels can't really help. Octocanium gets around this with omni/mec wheels. If this is the case your turning will basically stink. (unless you're wide) Unfortuantly, you can't just throw another wheel in the middle and chain off it because it won't switch ratios with the other wheels.
Based on what you've given us I think I see the general intent but I'm not sure that you've thought all the way through everything as it appears here.
I am not afraid.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
  #82   Spotlight this post!
Unread 25-11-2012, 23:39
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
The rest of it pivots this one portion of it shown here in its entirety and this is used to make the whole bot pivot?
I'm probably not even close, I've never been on drivetrain team.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
  #83   Spotlight this post!
Unread 25-11-2012, 23:45
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
When you say "both wheels are actuated", it sounds as if you mean independently actuated--if so, along what line of action?
If not, what we have is a pivoting drivetrain module with two wheels at different gear ratios and diameters. The wheel are indeed drive wheels, powered simultaneously but contacting independently (meaning the treads shown contact the ground one at a time?) The special thing has something to do with changing the 3D position and/or its first derivative with respect to the chassis on which these units are mounted. I feel like it has something to do with being able to turn. As it stands, this seems like it would be really bad at turning--at least versus the work put into it--but it's definitely not swerve...
EDIT: Bryan beat me to #2 and 3 (though he did 3 way better than I did).
All that, and you know what bugs me? that little peg thing inside the triangular pivot axle support. What's up with that thing?
  #84   Spotlight this post!
Unread 25-11-2012, 23:48
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
Just because no one's said it yet, I'm going to take a guess that this is for a ball drive.
Something similar to http://sphericaldrivesystem.com/
But on second thought, I dont' see how that could work without omni's for wheels.
If it's not a ball drive, I'm still going to guess that these wheels don't touch the carpet directly.
  #85   Spotlight this post!
Unread 25-11-2012, 23:52
Captain
4. If these are going on the Outer corners of a chassis I would be concerned about being able to turn. Your basically running a four wheel drive which picking up some wheels can't really help. If this is the case your turning will basically stink. (unless you're wide) Unfortuantly, you can't just throw another wheel in the middle and chain off it because it won't switch ratios with the other wheels.
I am not afraid.
Regards, Bryan
I can assure you that you definitely do not "see the general intent", unless that "general intent" is to drive the robot. None of you said is relevant to the overall idea of this mechanism.
As for the pivoting axis, what you see are spacers covering the actual moving axles. The middle axle is only used for, apart from holding that big pulley in the middle, mounting the pulley system to the oddly-shaped plate that you see.
  #86   Spotlight this post!
Unread 25-11-2012, 23:55
doot doot
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
The power source for Doc Brown's Flux Capacitor
  #87   Spotlight this post!
Unread 25-11-2012, 23:59
AKA: Voltonless
FRC #3260 (SHARP)
What are the benefits of a ball drive?
Team SHARP
  #88   Spotlight this post!
Unread 26-11-2012, 00:03
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
I think he created this as a joke; and it actually serves no purpose.
OR
We will all bow to this magnificent revolutionary on January 5th.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
  #89   Spotlight this post!
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
I think someone suggested 180 degree but it seems like it is designed to pivot around maybe 90 degrees. Notice the cutout around the smaller wheel is large enough to fit the larger one as well. (although this may be for aesthetic/symmetrical reasons) What that would buy you I have no idea though. Maybe you can drive a second mechanism from the smaller wheel in an upright position?
Edit: nope
It definitely doesn't pivot that much
Well is looks like it definitely flips in the direction of the larger wheel with the larger wheel traveling under to other side raising the small wheel way up in the air and flips the CIM completely to the other side...
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
  #90   Spotlight this post!
Unread 26-11-2012, 00:12
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Cory, I am with you. I have absolutely no interest in this guessing game. Why am I posting? I have absolutely nothing better to do. This is a guy who just joined CD the day he posted this so this is his first post. Here is a 17 year old who is probably a senior this year and a team captain and this is his 4th year in FRC. Why is everybody else posting? Definitely not for the $15.
And why should I be afraid? Is it because if your robot is on the field, then mine should not even be used because yours is that awesome.
Please don't call me Mr. Ed, I am not a talking horse.
