Go to Post There can be a fine line between intimidation and inspiration when it come to the elite in FIRST. Those teams who have committed to setting the bar for excellence in ways that change the culture, help to draw that line and deepen it. - JaneYoung [more]
Unread 26-11-2012, 12:25
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
Re: Be afraid... Be VERY Afraid
1. There are two advantages that we have seen so far. The first is a serious weight reduction as we don't need AM shifters. Also the ball will be made of carbon fiber wrapped in some undecided traction material. We also get a bit more friction if we were lets say trying to be pushed by another robot. This is due to the fact that we can put the driving wheels perpendicular to the incoming force, thus allowing the friction between the ground and the ball as well as the driving wheel and the ball. The second advantage is that we can easily disengauge the ball completely and use it as a "castor wheel".
2. LabVIEW. We have written some preliminary algorithms for the basic driving. We are now working on automating some maneuvers.
3.We still haven't decided on the exact cylinder, but will most likely use the tiny cylinder in the KOP (I can't remember the bore size). It will be mounted on a pivot point at an angle from the floor to the right of the big drive wheel.
4. We are aiming at less than 3 lbs (without including the CIM). This will depend on what materials we use (carbon fiber, aluminum, titanium). It will be a modular plugin to the chassis.
5. I have taken this into consideration, so in response, we will only be using this system if it is successfully running in a fair amount of time.
Stevens Institute of Technology
B.A - Electrical Engineering 14'
Mentor - FRC 714 (2012-Present)
Student - FRC 714 (2009-2010)
2013 Bridgewater-Raritan Winners (Thanks 1676 & 3314)
2012 MAR Regional Championship Judges Award
2012 Mount Olive District Excellence in Engineering Award
2012 Chesapeake Regional Finalist (Thanks 2068 & 358)
2012 Hatsboro-Horsham District Gracious Professionalism Award
