Go to Post I'm always afraid of what the GDC will come up with... Their sanity is often questioned... :D - thefro526 [more]
  #121   Spotlight this post!
Unread 26-11-2012, 12:25
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
Re: Be afraid... Be VERY Afraid
1. There are two advantages that we have seen so far. The first is a serious weight reduction as we don't need AM shifters. Also the ball will be made of carbon fiber wrapped in some undecided traction material. We also get a bit more friction if we were lets say trying to be pushed by another robot. This is due to the fact that we can put the driving wheels perpendicular to the incoming force, thus allowing the friction between the ground and the ball as well as the driving wheel and the ball. The second advantage is that we can easily disengauge the ball completely and use it as a "castor wheel".
2. LabVIEW. We have written some preliminary algorithms for the basic driving. We are now working on automating some maneuvers.
3.We still haven't decided on the exact cylinder, but will most likely use the tiny cylinder in the KOP (I can't remember the bore size). It will be mounted on a pivot point at an angle from the floor to the right of the big drive wheel.
4. We are aiming at less than 3 lbs (without including the CIM). This will depend on what materials we use (carbon fiber, aluminum, titanium). It will be a modular plugin to the chassis.
5. I have taken this into consideration, so in response, we will only be using this system if it is successfully running in a fair amount of time.
Stevens Institute of Technology
B.A - Electrical Engineering 14'
Mentor - FRC 714 (2012-Present)
Student - FRC 714 (2009-2010)
2013 Bridgewater-Raritan Winners (Thanks 1676 & 3314)
2012 MAR Regional Championship Judges Award
2012 Mount Olive District Excellence in Engineering Award
2012 Chesapeake Regional Finalist (Thanks 2068 & 358)
2012 Hatsboro-Horsham District Gracious Professionalism Award
  #122   Spotlight this post!
Unread 26-11-2012, 12:41
Chris is me's Avatar
AKA: Pinecone
Thumbs up Re: Be afraid... Be VERY Afraid
It looks like this ball is only powered on one axis. In that case, why a ball and not a wheel?
  #123   Spotlight this post!
Unread 26-11-2012, 12:49
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Cool! Thanks. Followups:
1A. I'm missing how you get "more friction". Isn't the first place you slip the only one that matters? I guess I'm not understanding what you intend to do (in part because of Chris's question).
1B. What's the benefit of turning it into an caster wheel in this setup?
4. Wow, 3 pounds? Keeping that in-cost is definitely impressive. What's the ball diameter?
  #124   Spotlight this post!
bhumudar's Avatar
Again due to the weight reduction advantage. The module its self is able to rotate 360 degrees to give the swerve effect. Also this whole project is a way for us to satisfy our engineering curiosity and out of the box thinking.
  #125   Spotlight this post!
Unread 26-11-2012, 12:56
bhumudar's Avatar
Siri,
1. You are correct in that the first place that you lose friction is the only one that matters, but since there are multiple contact points, each one adds to the total friction available. Lets suppose you see an incoming robot front the right of our robot, we would turn the wheels so that they face front to back (perpendicular to the incoming force).
2. It would simply be used as a built-in neutral position which may or not help with this years game.
3. I believe the diameter is about 4 inches.
  #126   Spotlight this post!
Unread 26-11-2012, 13:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Maybe I'm a cynic, but until this design gets the Aren Hill Seal of Approval (or at least his thoughts), I dunno that I'd put it on the field during the season. Aren has more experience with different/non-standard swerve designs than any single person on these forums. OP, I'd message him specifically if I were you.
Also, post the overarching design as a Photo to get more/better feedback -- the veterans on these forums tend to write these types of threads off as more chatter when sifting through the noise. "Be VERY Afraid" will not get you a whole lot of constructive feedback on a technical design.
Presentation aside, it definitely looks interesting.
2017 Scoring Model
CAD Library | GitHub
  #127   Spotlight this post!
Unread 26-11-2012, 13:07
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Beautiful CAD! But the concept I'm a bit skeptical about. What happens if your robot is hit really hard? Can the ball become dislodged? It looks like you are relying on gravity and the wieght of the robot to actually hold it onto the ball. What if your Robot CG is higher and your drive ball becomes a part of the field accidentally?
Thats what I see.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
  #128   Spotlight this post!
Unread 26-11-2012, 13:09
FRC #1836 (MilkenKnights)
1) I can see a couple of problems here. First of all I'm not sure you can get as much traction on that ball as you would wish. The common matertial that I would think of using to cover the ball is roughtop. However roughtop's performance on carbet is directly related to how much tread is touching the carpet. Second the locking system that you described can be done with a regular swerve. However with a regular swerve it is mechanically impossible for the wheel to roll, so you will have a greater resistance to being pushed. Also this whole setup is less efficient. Lastly you usually don't want castor wheels. In this setup specifically you will lose motor power. However I could see them being useful maybe on the bridge this past year.
4) A pound or two more it seems like you could do mini modules like 1625 did. This setup would be much more efficient than your current one, and for the performance gain it would probably be worth the weight. Try getting modules as small as possible. I have done it and it is a very interesting design challenge.
  #129   Spotlight this post!
Unread 26-11-2012, 13:16
Brandon Holley's Avatar
I think the way you are wording this statement is misleading. Siri's statement that you reiterated is very important- whatever slips first is the limiting factor.
I believe I understand what you are saying, that by moving the wheels perpendicular to the incoming force, you are using the traction of the ball and floor as your traction limit as opposed to the traction limit on the wheels against the ball. What is hanging me up is the part where you say "each one adds to the total friction available". This is not a summation, your maximum theoretical resistance to pushing (or traction) will be limited by the ball's traction with the floor.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #130   Spotlight this post!
Unread 26-11-2012, 13:20
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
-Brando
Wouldn't it then be the: ball traction - wheel traction = Max. Theoretical Traction.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #131   Spotlight this post!
Unread 26-11-2012, 13:22
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
Doesn't a sphere give you a disadvantage as far as friction is concerned?
In a perfect spere only one point would be tangent to the ground.
In a wheel, the entire width of the tread is touching the ground.
Am I missing something?
  #132   Spotlight this post!
Unread 26-11-2012, 13:25
Regularly your traction is based on weight and COF. However with roughtop the tread locks into the carpet so this is ture.
  #133   Spotlight this post!
Unread 26-11-2012, 13:26
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach
VRC #15842 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
I would not have guessed this... thought it was a re-imagining of the Nonadrive corner module... though, I'm a pretend engineer and THAT'S my excuse...
QUESTION: I don't see anything that leads to structure that holds the chassis up? Where's the shaft that this spins around on that will support the weight of the robot?
I'm assuming the shaft will be on the top-side of what's shown so far... or, are you going with a "Lazy Susan" on top with this fastened underneath and attached with standoffs (like the large gear below)?
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
  #134   Spotlight this post!
Unread 26-11-2012, 13:59
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Hrmp. My delete button is broken.
  #135   Spotlight this post!
Unread 26-11-2012, 14:03
Siri's Avatar
Dare greatly
What's the full weight of the unit (with swerve)? And what leads you to believe the ball system will be lighter than using wheel?
Do you propose that the system will begin slipping between the ball and the rollers or between the ball and the floor? (Why?) I think Brandon and I are both stuck on how aligning the rollers increases this threshold vis a vis a system that doesn't use a frictional drive for steering (i.e. a belt, chain or gear swerve).
And listen to Jesse; you really want to talk to Aren.
Tom: secret's out. OP should probably edit the original post.
