Go to Post At first, "water game" was funny. Then it went to silly. Now it's just dumb. Not to mention unrealistic for FIRST. - EricH [more]
  #31   Spotlight this post!
Unread 31-10-2012, 22:53
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: #25 Chain Drive Experience ???
Originally Posted by de_ View Post
Hi Rob
Where do you buy the thicker AL #25 sprockets ?
Re the Dark soul tool ( http://www.team221.com/viewproduct.php?id=70 ) I had no idea that it got rid of the masterlink. Thanks
Dave
AM used to sell thicker sprockets with a chamfer. Now they are thinner with no chamfer.
-RC
R.C.
MadTown Robotics Team 1323
  #32   Spotlight this post!
Unread 01-11-2012, 14:31
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Unfortunately I don't have a source for aluminum sprockets other than Andymark. I was just pointing out the change in quality in recent years.
I did some hunting around and found some aluminum sprockets with hubs made by Berg. These use set screw hubs and "pin hubs" so it may be best to broach a keyway in them.
www.wmberg.com/catalog/catpage.aspx?url=pdf/B05A107.pdf
I also found some glass reinforced nylon sprockets made by Torque Transmission.
torquetrans.com/roller-chain-sprockets/index.htm
I will give their distributors a call and see what their stock looks like.
These look interesting. Please let us know if you get pricing and availability. We tried using a large nylon sprocket from Mcmaster carr on our intake this year, and had trouble with the chain not engaging properly. The pitch seemed to be off for some reason.
Generally chain "stretching" is every little join on every link wearing.
The reason you see more stretch on #25 is not because it is weaker but is because you have more links per inch to wear down.
This makes a lot of sense. Team 359 uses bike chain which is 0.5" pitch, but much narrower than standard #40 chain. I'd be curious to hear from them how much stretch they see (if any). My understanding is that bike chain is way stronger than #25, but lighter than #35. Unless you could adapt bike sprockets, you would have to make your own. Other than that, it seems to be a great compromise between #25 and #35 chain.
Rob
  #33   Spotlight this post!
Unread 27-11-2012, 00:00
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Sorry to pull up this thread again, but has anyone found a reliable source for chamfered #25 aluminum sprockets? Does anyone know about these RobotShop guys?
  #34   Spotlight this post!
Unread 27-11-2012, 08:57
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
I've never heard of them, but I'd suggest checking McMaster-Carr.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
  #35   Spotlight this post!
Unread 27-11-2012, 09:11
Siri's Avatar
Dare greatly
Unfortunately, McMaster has never sold aluminum sprockets. (They're strictly steel/stainless and nylon.)
  #36   Spotlight this post!
Unread 27-11-2012, 09:41
Sorry about that, missed the aluminum part of your post. It looks like many of the #25 sprockets on AndyMark are aluminum. Are they not chamfered, or the wrong size, or something?
  #37   Spotlight this post!
Unread 27-11-2012, 09:58
Siri's Avatar
Dare greatly
Yes, AM changed their #25s at some point. They're now thinner and no longer chamfered, and we're having systematic issues with CNC notch defects. There was a bunch of talk earlier this month about it, but it was never resolved into a different supplier. We're currently looking either at fixing the bolt pattern and bore on the less expensive RobotShop ones or crossing our fingers and trying to lathe a chamfer on AM's thinner ones. Wondering if anyone found a different solution.
Originally Posted by R.C. View Post
AM is the only person in the market that sells sprockets in #25 in aluminum. Maybe some other supplier might, WCP will in the distant future
Originally Posted by philso View Post
My concern with exchanging the sprockets is that it would just be a waste of time. Since both sprockets had the same "notch" in them, this is indicative of the design or the CNC programming of the sprocket so any replacements would also likely have the same flaw.
  #38   Spotlight this post!
Unread 27-11-2012, 10:23
Joining the 900 Meme Team
FRC #0079
I've never ordered sprockets from them but I ordered a couple robots kits from them for work. The kits were backordered but other than that arrived fine and worked quite well. Just don't try calling their phone support, it's terrible.
  #39   Spotlight this post!
Unread 01-12-2012, 12:59
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Does anyone happen to know, off-hand, what the change in material thickness on AM sprockets was? I'm looking for the thickness of a sprocket with chamfer versus one without a chamfer.
--Madison--
...down at the Ozdust!
  #40   Spotlight this post!
Unread 01-12-2012, 13:37
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
I believe the new sprockets are .125" thick. I know they are waterjet.
I'm not sure however how thick the prior ones were.
EDIT: Sorry, I was talking about plate sprockets. Should have been more careful.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
  #41   Spotlight this post!
Unread 01-12-2012, 14:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Waterjet?
There's no way they're waterjet, unless you're talking about plate sprockets. It would make absolutely no sense to waterjet the tooth profile then turn them down to create the hub.
2001-2004: Team 100
2006-Present: Team 254
  #42   Spotlight this post!
Unread 01-12-2012, 18:38
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
I could believe that the larger plate sprockets are waterjet. As far as I know, the smaller sprockets with a hub are still machined, and still have a chambfer.
  #43   Spotlight this post!
Unread 01-12-2012, 20:00
Siri's Avatar
Dare greatly
Originally Posted by Cory View Post
Waterjet?
Is something wrong with the hubbed sprockets? I'd only had/noticed people discussing issues with the plate versions. (Type A for AndyMark)
And thank you, Andrew. We'll probably get one from them, then.
  #44   Spotlight this post!
Unread 02-12-2012, 00:40
Cory's Avatar
AKA: Cory McBride
Oops. My bad. Poor reading comprehension on my part. Didn't realize which was being discussed.
2001-2004: Team 100
