Go to Post We are different, but in our differences we help the world continue to grow, change, become inspired. Different is NOT bad. Be true to your self, be weird, be dorky, be crazy, be a geek. :) - chellyzee93 [more]
Unread 27-11-2012, 19:16
Wsen Wsen is offline
FRC #0057
Wsen is an unknown quantity at this point
Pneumatics
I'm working on a project involving the valve in the picture. I'm using it to set off eight pistons that only need to shoot out once. I'm not entirely sure how each piston is suppose to be connected. Please help
Unread 27-11-2012, 20:03
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: Pneumatics
If all the pneumatic cylinders can be fired together, you can take the two outputs of each solenoid valve and put it in a T fitting/Y fitting. (http://www.andymark.com/product/am-2184.htm)
This would be similar to wiring a electronic circuit in parallel.
My team did this in 2011, so I'll try and find a picture.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 27-11-2012, 20:49
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Re: Pneumatics
I love that thing. My team has the exact same one.
Each piston has a valve at the bottom and top. One that's filled with air, and one that's exhausted of it. Hook up each end to the two connectors on one of the solenoids. Then you hook up the actual solenoids with a connector to the bumper on the cRIO (from which you control the solenoids).
Lastly, this whole thing should be connected to your entire pneumatics circuit (featuring compressor, air tanks, pressure gauge, release valve).
So, essentially, what happens is, there's always pressured air accessible to the unit. Whenever one of these solenoids receives a signal from the cRIO to open up, one of the valves will open and allow the pressured air to enter the piston.
If the piston goes in reverse direction of what you expected (extend rather than retract), just change which valve the pneumatic tubing is leading into on the solenoid.
Unread 27-11-2012, 23:03
Re: Pneumatics
The picture looks like four "dual solenoids" in one manifold. Unless you have some highly unusual requirements, it'll only be able to control four pneumatic cylinders properly.
What is your application for "setting off pistons"? Are they required to be independently actuated?
Unread 27-11-2012, 23:34
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Pneumatics
[old man rant]
Can we please stop calling them pistons? They are cylinders!
[/old man ran]
Unread 29-11-2012, 11:59
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: Pneumatics
you'd cut your flowrate in 1/2 though.
My Instructables
Unread 29-11-2012, 13:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Pneumatics
It would also help to know what type of pneumatic cylinders you have. Do they have a fitting at each end? or just at one end?
